Old 05-21-2013, 03:17 PM   #1
Blue_Aura
Blue_Aura's Avatar
62 - What 4-Way Switch Do I Need?
So the problem I am experiencing is that my Driver's front blinker lights up when I step on the brake, and my signals do not blink. I know that I need a new 4-way flasher, but when I was looking for a replacement I found many different flashers available.
Anyone familiar with a 62 4-way flasher I should use?
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline   Reply With Quote
Old 05-21-2013, 03:41 PM   #2
tincan1966
tincan1966's Avatar
Re: 62 - What 4-Way Switch Do I Need?
Probably not the flasher, but rather the turn signal switch , itself may be malfunctioning.
Do you have an original steering column?
tincan1966 is offline   Reply With Quote
Old 05-21-2013, 03:53 PM   #3
Blue_Aura
Blue_Aura's Avatar
Yes, I have the original column. I'll have to pull the wheel and check to see if the cam even has the contacts. If the switch is bad, it will cause the overflow of electricity from the brake switch also?
Current Vehicles:
Some Past Projects:
Old 05-21-2013, 04:11 PM   #4
tincan1966
tincan1966's Avatar
Alot of guys with more experience than me have been able to clean up these switch when they start to not work correctly. I remember someone recently has having trouble finding the correct parts for the 62-63 column. I have a good switch for a 63 bu tthe cancelling part is broken. electrically it works great. It has the metal housing, not all plastic. Once you get the wheel off, take a couple pics and some of the guys can help identify which switch you have for sure.
PM me if you are interested in this switch, I really do not need it, I don't use stock columns.
Old 05-21-2013, 04:14 PM   #5
Blue_Aura
Blue_Aura's Avatar
Will do. Thanks!
Current Vehicles:
Some Past Projects:
