06-25-2003, 03:33 PM | #1 |
Heater hoses.....
Does anyone have pics of the 2 hoses that come from your heater box? I need to know where they go to. 1 of them goes to a sensor on my intake but where does the other go?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
06-25-2003, 03:41 PM | #2 |
On my 71 blazer, the top one goes to the top of the intake manifold and the other goes to the top passengers side port on the radiator.
Brian |
06-25-2003, 03:51 PM | #3 |
I don't have a port on the side of my rad for the second hose. I have a plug in the top of the water pump on this 350 and it looks like there should be a hose go onto there. HELP!?!?!?
06-25-2003, 03:53 PM | #4 |
CCRider
It should go to the side if the waterpump...right above the radiator hose
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
06-25-2003, 04:20 PM | #5 |
I know the one on the intake is for one of the hoses, but i think the other goes where that plug is on top of the water pump.
06-25-2003, 04:25 PM | #6 |
Resident Curmudgeon
This does not show it too good because a fan blade is partially in the way but, here's how it should go
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
06-25-2003, 04:27 PM | #7 |
Resident Curmudgeon
better view
06-25-2003, 04:29 PM | #8 |
I don't have a port there
06-25-2003, 04:34 PM | #9 |
Resident Curmudgeon
See! What did I tell you about not following the manufacturers recommended installation? See! I told you so! If you'd done it by the book it'd be done now! No fuss no muss. Now you're f__ked
Seriously, can't help ya now. Maybe with that pump they were figuring you'd have a place to connect on the radiator?
06-25-2003, 04:40 PM | #10 |
This engine is from an 82 Chevy van. So it wouldn't go where that plug is on the top pic I posted? It also goes into the water pump?
06-25-2003, 04:40 PM | #11 |
its all about the +6 inches
You can take your rad to a shop and they could install the fitting you need. Most should have the stuff on hand, and it'll only cost a few bucks. Figure one hr of labor.
Can't go without heat up there. |
06-25-2003, 04:44 PM | #12 |
CPNE- Mine are just oposite of that my top one goes to the block and lower one goes to the Rad nipple, I might have my core upside down though
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
06-25-2003, 04:46 PM | #13 |
Resident Curmudgeon
That one may be too. Anyway I don't think it matters too much as the pump is pushing it through no matter what.
06-25-2003, 04:54 PM | #14 |
So as long as 1 of these hoses is coming from the water pump I should be OK? I am sorry if these are kinda dumbass questions but this is my first engine build up
06-25-2003, 05:11 PM | #15 |
you need a in and out!
06-25-2003, 05:12 PM | #16 |
There are two main styles of chevy water pumps. The older short pump will have the port on it for the return of the heater core. the newer long pump setup dumped into the radiator for return. Problem is if you go to a short pump none of your brackets will work, they are different.
1970 C10: 2WD, LWB, 350, 350 auto, Headers, Duals, Edelbrock 1406 with 2101 intake, and optional rust. |
06-25-2003, 05:13 PM | #17 |
CCRider
Try it and let us know
06-25-2003, 05:26 PM | #18 |
huh?
Are BB's and SB's the same?? (I really don't know... :\)
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
06-25-2003, 05:35 PM | #19 |
Hey dubbie, That plug was right on top of your water pump right? On mine, it used there used to be one out of the top of the water pump and one out of the manifold. Like someone else said, I don't think it matter that much which hoses go where though. Good luck.
Low68
Build Thread |
06-25-2003, 06:15 PM | #20 |
anyone have pics of the fitting on the rad? Just so I know where it goes? So many different opinions here. Does anyone know for sure if i can just use the plug on the top of the water pump?
06-25-2003, 06:24 PM | #21 |
Robert Olson Transport
see post onm 73 -87 message board
06-25-2003, 09:04 PM | #22 |
huh?
Yes, you can
06-25-2003, 10:02 PM | #23 |
OK, a buddy of mine just bought a 69 long fleet tonight and it has a 305 in it with the same set up. And YES , I can remove that plug on the top of the water pump and run the 2nd hose through there. Finally my mind is set at ease. Thanks for all the great info guys
