91 Suburban 4wd Steering Questions? Wandering?
I am in need of some help. I have installed a new steering box and stabilizer because it seemed worn out and felt like truck was all over the place. Didnt seem to help a whole lot. What else should I check? This is my first four wheel drive so not real familiar with what wears out, or if thats just the way they are. I was thinking about replacing the pump because sometimes it steers easier than others and also getting a front end alignment. Any suggestions or help will be greatly appreciated.
Never a failure, Always a lesson! 1968 Chevy SWB Fleetside ECE 4/6 327/350 1987 Chevy V20 Scottsdale 4X4 350/400 4.10 1987 Chevy Custom Deluxe SWB 305/7004R4 1991 Suburban Silverado V1500 4X4 350/700R4 2015 Chevy Crew Cab SWB (Daily Driver) 5.3 |
Re: 91 Suburban 4wd Steering Questions? Wandering?
Rag joint or coupler from the column to steering box to start with. Both rod ends of the drag link (connection from pitman arm to steering arm) and both rod ends of the tie rod (knuckle-knuckle connection).
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
Check your upper and lower ball joints too.....
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
In the Forgotten far North.
![]() Join Date: Jul 2007
I just replaced all the ball joints, tie rods, and drag link assembly on my 3/4 ton. Made a world of differance considering the tie rods fell apart while trying to seperate them from the steering knuckles. Also replaced the front axle u-joints while I was in there.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
