![]() Join Date: May 2012
engine harness Q:
I am trying to hook up my engine wire harness on my 72 C10. the harness had all the ends cut off and I am not sure where all the wires go. Does anyone have a color diagram that shows this?
thanks |
member #16
![]() Join Date: Dec 1999
Re: engine harness Q:
There is a sticky with the wiring diagrams at the top of the electrical page.
Here it is. http://67-72chevytrucks.com/vboard/s...d.php?t=185856
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
While the color chart is a start it is very generic. The 72 service manual (downloadable) has most of the circuits. If it is just the engine harness you shouldn't have to much trouble.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Is the green for temp? purple to starter? brown to starter? etc...
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here is on I like to use. The wires on the left are for the parking and turn signal lights. The temp is green, the oil is dark blue, and the purple goes to the starter solenoid along with a yellow which connects back to the coil positive terminal for 12 volts during starting.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
