05-21-2013, 11:26 PM | #1 |
Hellasick
Brown-Sleigh Santa showed up today
Brought me my tax refund!!!!
Doesn't show the new damper, gaskets, bolts or more importantly the Vortecs and intake I got from Indian113. And for those curious, it is a voodoo 250/256. Good thing I took this week off!!!!
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
05-21-2013, 11:34 PM | #2 |
Re: Brown-Sleigh Santa showed up today
Is your uncle Sam going to come over and help you put all that together
05-22-2013, 12:06 AM | #3 |
Hellasick
Actually, step-uncle twice removed...
05-22-2013, 12:07 AM | #4 |
Nice refund
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-22-2013, 08:39 PM | #5 |
Hellasick
My thoughts exactly!!
Now for today's progress report.... Swapped the valve springs this morning and got this far with the tear down. And all tucked in for the night. An old sheet from an ex-gf, now a really big rag.
05-22-2013, 09:04 PM | #6 |
6>8 Plugless........
You're making some nice progress Chad! Thumpty thump thump.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-22-2013, 10:04 PM | #7 |
Hellasick
Thanks Ryan, hope to have it going tomorrow. The one and off rain today slowed it some.
05-22-2013, 10:58 PM | #8 |
I bet so. This weekend doesn't look much better either.
05-23-2013, 09:26 PM | #9 |
Hellasick
Made some more progress. After fighting getting the oil pan down to clear the timing cover, I decided to go ahead and put on the heads. Cover up them holes and stop any flash rust.
After that and a brain clearing conversation with Indian113 I found I was fighting myself, not the pan. I had missed a couple bolts So then got the timing cover, timing set off. Tomorrow I should have the cam in etc.
05-24-2013, 10:49 PM | #10 |
Hellasick
No pics today, but I did get the cam swapped, timing set installed and the balancer as well. I had measured the new cam and verified there was enough room to pull it out without removing the grill. Only an inch or so, but that was enough.
Not as much done as I would have liked, but had lunch with my dad and later had a wedding rehearsal and dinner to go to. Not mine, a friend/co-worker's. Nothing kills the job like having to stop to clean up twice in one day. We will see how the weather is tomorrow, before heading off to wedding.
05-27-2013, 09:23 PM | #11 |
Hellasick
Got a few minor things done Saturday but not a whole lot.
Sunday I started by removing some obsolete wiring, 12v from starter to distributor and the TSC wiring. This led to finding the bolts for the starter solenoid were MISSING and to think I had no troubles starting it. Got the balancer pulley installed. Installed new water pump. Not real productive but that's ok. Today--- Dropped starter to find out bolt size for solenoid mounting, replaced bolts and put starter back. Put lifters in and cleaned and installed push rods. Set pre-load and installed intake. Due to the temp sensor size issue, put original into intake for now. Fuel pump hooked back up along with alt, but need different belt now-valve cover in the way, but should have enough adjustment. Need to cut and weld the kick-down bracket to fit the wider bolt pattern. Installed water pump pulley. The old balancer must not have been on all the way, I removed the washers used to shim the alt and PS pump out to line up the belts. Not needed now. New balancer also has the correct timing mark too!! Hell is in the details!!!!!!!!!!!!!!! It's looking a lot like an engine now!
06-09-2013, 10:01 PM | #12 |
Hellasick
IT'S ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Well, its been alive for a week now, wanted to make sure it was all good and didn't have an o-crap moment. Had to add 2 inches to the alt arm to clear the valve covers of course. Almost had it fired up last saturday, but was cleaning schmutz from the plug wires and found one was cut and another had a burn spot. NO ONE had a decent set of wires in stock, AZ and Oreilly's had store brands, but wasnt' gonna waste my money on those and missed Oreilly's warehouse by 1 hour. Bought a set of BWD's and picked them up Sunday morning at the warehouse. Double, triple and quadruple checked everything and fired it up early Sunday afternoon. Took most of the 20 min. break in to get rid of all the anitfreeze that ran down the exhaust pipes from pulling the heads. Nope, didn't actually drain the block first. I'm sure my neighbors loved me for that one Runs great, MUCH louder than it was before, especially when you get on it. Took a couple videos with my phone, they are't great, but I'll try to get em uploaded. Now I HAVE to drive it for another 500 miles to continue the break-in
06-09-2013, 10:56 PM | #13 | |
The Older Generation
Well, you could drive it to Montezuma and help me break mine in... LockDoc
06-09-2013, 11:11 PM | #14 |
Hellasick
Sounds like a good excuse to me.
06-12-2013, 04:49 PM | #15 |
Glad to hear you got it back up and running Chad!
