Old 05-22-2013, 01:04 AM   #1
kevmcrae
kevmcrae's Avatar
Replace DOT 3 with DOT 5 Brake Fluid
Anyone ever changed from conventional DOT 3 to DOT 5 silicone based? I discovered my proportion valve had leaked over the winter and of course peeled the paint right off my inner fender!*^&$%^%^#!!! Bought a new chrome master cylinder with the proportion valve built in and thinking of changing to DOT 5 so I never have to worry about a brake leak ruining any paint. Had one guy tell me flush with alcohol, blow the lines out with air hose, and bleed with the new fluid?
Any other experience, advice, opinions?
Kev
kevmcrae is offline   Reply With Quote
Old 05-22-2013, 01:16 AM   #2
rattle69
rattle69's Avatar
Re: Replace DOT 3 with DOT 5 Brake Fluid
Problem is dot 5 is racing fluid. It is to be changed always. It is not hydroscopic meaning meant to absorb water. If left in too long dot 5 will loose it's boiling point much faster that dot 3 or 4. It is used for racing only. Dot 5 is not recommended for every day use. Supercars come with dot 4...
70 lwb c-10
rattle69 is offline   Reply With Quote
Old 05-22-2013, 02:18 AM   #3
Rufton
I would consider mineral oil for mild performance applications if entire system is brand new. Dot 3 exposed seals will be damaged by mineral oil. Not fond of Dot 5 because condensed H2O can pool and cause corrosion and performance issues. I use Dot 3 and change fluid every few years to avoid corrosion. Fresh Dot 3 has corrosion inhibitors. Dot 3 can damage paint. Quickly remove Dot 3 from paint w/ H20 or dish soap + H2O. Dot 5 can cause fish eyes when repainting. Not easy to completely flush system before changing to incompatible fluid.
Rufton is offline   Reply With Quote
Old 05-22-2013, 06:17 AM   #4
zeeklu
I used dot 5 in my truck around 10 years ago. I replaced all the lines and every thing else. The fluid is still perfectly clean. My 2002 Harley came stock with it.
zeeklu is offline   Reply With Quote
Old 05-22-2013, 11:45 PM   #5
BigRed76
BigRed76's Avatar
My knowledge of the brake fluid differences is limited, however I've seen/heard of a lot more people converting to DOT 4 rather than DOT 5.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 05-23-2013, 09:10 AM   #6
Fldawg
Fldawg's Avatar
when i did my 4 wheel disc conversion i went with dot 3 synthetic , it's not suppose to attrach moisture like regular dot 3 , so far so good
Fldawg is offline   Reply With Quote
Old 05-23-2013, 09:25 AM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I run DOT 5 in my K20 and K5. No problems. All brand new components when I decided to use DOT 5.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 05-23-2013, 09:32 AM   #8
67 chevelle
67 chevelle's Avatar
use dot 5.1 , not 5 , 5 is silicon and will not play well retrofiting your old system , 5.1 is great stuff being compatable with dot 3 and 4 , but has superior performance , higher boiling point , if you had a dot 3 system that was low you could top off with 5,1 , if you put 5 in it would destroy everything . i went thru a 3 year strugle with a brake issue in a 67 chevelle tryed every fluid , 5.1 was best , I tryed wrapin headers , lines , moving line and the brakes would lock after a few miles , even changed headers , turned out the rod from the booster was 1/16 of an inch too long into the master 2 5 cent washers between the booster and master solved the problem , since I have seen the same issue several times .
67 chevelle is offline   Reply With Quote
Old 05-23-2013, 05:11 PM   #9
Crabass
Some info you might find interesting:
http://www.superchevy.com/technical/.../0509sc_fluid/
http://www.duntovmotors.com/tech-brake-fluid.php
Crabass is offline   Reply With Quote
Old 05-23-2013, 06:56 PM   #10
Bigdav160
Bigdav160's Avatar
DOT 3, DOT 4, DOT 5.1 are glycol based fluid and will remove paint
DOT is silicone based and doesn't remove paint. It has some drawbacks but nothing I'd worry about.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-24-2013, 02:00 AM   #11
kevmcrae
kevmcrae's Avatar
Thanks to all for your replies. And thanks to Crabass for the links. Gave me a lot more to think about.
Old 05-24-2013, 08:41 AM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Every single vehicle in the Postal Service delivery fleet uses DOT5. All day every day. No racing, just work. It's good stuff.
