Exhaust Question
So where are you guys running your exhaust. I would like to see some pics because I am not sure where to run the pipes....through the rear suspension xmember?? And how about routing the pipes around the rear trailing arms??
![]() Join Date: Oct 2012
Re: Exhaust Question
Stock exhaust (230 I6, single exhaust pipe) starts at post 98.
Pretty much off the manifold, down the DS frame rail, up over the DS rear truck arm, over the DS axle tube and out at the DS rear corner of the truck. http://67-72chevytrucks.com/vboard/s...d.php?t=571916 |
This is a 1962 frame with torsion bars. Changing over to Porterbuilt front so it might change again. Patriot shorty headers and Flowmaster Delta 40s.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Here is the way it was for years.
327. 2.5" out of the manifold and immediately to the outer side frame rails to knock off Flowmasters and side exit at 45* just in front of the tires.
Senior Enthusiast
Here's a recent similar post with a variety of feedback:
http://67-72chevytrucks.com/vboard/s...light=mufflers
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
My father ran his just like Vin63 in that thread. Keeps all the pipes from hanging down, and keeps them out of the way.
