Old 05-22-2013, 07:01 AM   #1
Operatorfailure
Trying to assemble parts for my 4.8/5.3 4l80e swap, questions.
I'm trying to figure out the full list of things I am going to need so I have as much as possible before I yank the engine out of my 68 daily driver. If you see anything I'm missing, feel free to jump in and give me the heads up!
4.8 or 5.3 with full accessories and wiring harness (pedal and TAC module if DBW)
Motor mount adapters
F-body tank with homemade mounts using in tank pump, with new fuel lines including a return line.
4l80 with 6.0 flexplate
Fuse block and obd2 port for wiring harness
Radiator hoses
Wideband and o2 sensors
Exhaust
Intake tubing and air filter
I have hptuners so I will delete vats and swap segment for the 4l80e
I'm sure I'm forgetting things, if you happen to notice anything feel free to shoot me in the right direction!
Operatorfailure is offline   Reply With Quote
Old 05-22-2013, 05:17 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Trying to assemble parts for my 4.8/5.3 4l80e swap, questions.
I'm thinking the list is longer...but then again every build is not the same.
Curious as to why a 4L80e for a 4.8L? Are you planning to boost it or run lots of nitrous or something? Sure 4L60's break, and need to be built right to handle more power....but I wouldn't think an 80e is really necessary at the 4.8L level?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-22-2013, 05:24 PM   #3
orngsikL
orngsikL's Avatar
transmission lines
coolant
oil
trans fluid
what are you going to do with the steam line? tap the water pump?
coolant resovoir
headders
throttle linkage
all i can think of right now
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 05-22-2013, 08:57 PM   #4
Operatorfailure
A turbo is on the list later on and have had enough troubles with 60's in the past to just do it right the first time. And thanks for the other items, I have an aluminum radiator I will tap the steam line into.
Old 05-22-2013, 09:10 PM   #5
Mr. 250r
Mr. 250r's Avatar
5.3/6.0 instead =-p granted the 4.8 can definitely make power but i believe through internet heresy that it will be much easier using those 2 lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 05-22-2013, 10:18 PM   #6
68GMCCustom
trans mount and trans linkage/shifter
MAF included in donor stuff?
oh....unless you really like the short stroke of the 4.8L....go with the 5.3L
Kurt -
Old 05-23-2013, 05:41 AM   #7
Operatorfailure
If I get a maf sensor with the engine I will run it, if not I will tune it sd only. When I turbo it I will go sd anyway, so its no big deal. And yeah, I will need a shifter and trans mount, good thinking!
Old 05-23-2013, 06:51 AM   #8
truckdude239
truckdude239's Avatar
I used my stock linkage
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-23-2013, 02:55 PM   #9
Operatorfailure
I stumbled upon a killer deal on a 5.3/4l60e combo, as long as everything checks out I will be picking it up Sunday. I would much prefer an 80e, but for the price I will run it. What crossmember are people running on 60e swaps? I have a granny low 4 speed/350 combo right now so I know that won't work. I was thinking about hitting up junk yards for a th350 c10 crossmember and a tilt/auto column. Does anyone know if the auto columns for the 3 speed autos work for the 4l60e? I don't care if I can't drop it down into 1st, as long as I can hit p r n d. Thanks for all the help everyone!
Old 05-23-2013, 04:14 PM   #10
truckdude239
i used the stock auto cross member and stock th350 mount, i used the stock linkage and it goes into every gear i think
David fuller
2000 Tahoe 5.3l 378
Old 05-23-2013, 04:31 PM   #11
tinydb84
tinydb84's Avatar
Go to the how much does your ls swap cost thread. There are many parts lists with costs and part numbers.
David
Instagram: myfabguy
Old 05-24-2013, 07:59 AM   #12
Operatorfailure
Does anyone know if the 73-87 th350 crossmember will bolt up to a 67-72 frame without issue? They are a ton easier to get.
Old 05-24-2013, 08:28 AM   #13
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used the trans cross member from CPP, it worked great! and it is cheap and I didnt have to crawl under a junk truck to get it!
http://www.classicperform.com/Store/...uck/CP9427.htm
good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-24-2013, 01:14 PM   #14
Operatorfailure
Can you just buy the trans crossmember? The only way I have found it is with sbc engine perches and I don't need them.
Old 05-24-2013, 06:37 PM   #15
68GMCCustom
yes
Kurt -
Old 05-24-2013, 07:01 PM   #16
Operatorfailure
Thanks, I just got home and found it on summits website. For some reason on my phone all I could find is the combo deal with the motor mounts also. I will go ahead and update my first post to show what is needed.
Old 05-25-2013, 12:20 PM   #17
Ford Assassin
Ford Assassin's Avatar
4.8's aren't a bad lil engine. Might is stock internals except for the LS6/springs/pushrods and I made 430 to the wheels through a built 4L80e.
Oh and the supercharger helped alittle.....
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 05-25-2013, 12:51 PM   #18
Operatorfailure
I have wanted a turbo 4.8 since I read about all the guys on performancetrucks.net getting a ton of power out of them.
Old 05-27-2013, 10:30 PM   #19
68GMCCustom
but isn't that because they are cheap...and that after a while at 8-15psi or more of boost (probably from a cheap turbo system) does to an otherwise stock internal engine....so when they grenade it, and they will....they just get another one (for $500 or less) to replace it?
Kurt -
Old 05-27-2013, 10:39 PM   #20
Critter
Future TOTM Winner
Critter's Avatar
New drive shaft/altered used one
Sending unit for water temp if using original gauges
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-27-2013, 10:41 PM   #21
Ford Assassin
Yes and no. 4.8's generally live longer due to having the longest rod and the shortest stroke of ANY factory GM LS series engine. Because of the great rod to stroke ratio, the pistons aren't forced into the thrust side of the cylinder walls as badly and the rods aren't stressed as badly either. Plus the piston dwell is great, especially for a forced induction.
But believe it or not the 4.8 isn't super common, at least not compared to the 5.3 which has been built 2.5 times more than every other LS series engine COMBINED.
Cable
