Old 06-25-2003, 03:54 PM   #1
Professor
Help identify this light.
OK, I am putting the instrument panel back in and I can't remember where a light goes. It is a 69 C-10, 2wd, auto without power brakes but it does have gauges. The light bulb and socket seems to be one that screws into one of the light holes in the instrument panel, but I don't know which one. It is on a black wire that comes out of the steering column. I have both of the manuals for the 69 (chassis and overhaul), but I can't find it on the wiring diagram. HELP?
Professor is offline   Reply With Quote
Old 06-25-2003, 04:01 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
it is your column's fiber optic and you can put it in place of any of the lights in you cluster. The normal position is on the RH side (as you face it) of the speedo.
The recepticle uses a standard bulb to light your cluster and the fiber optic reflects the light to your gear selector pointer.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-25-2003, 04:18 PM   #3
Professor
There's fiber optics!!!!!!!?????????? Dang, Chevy was stylin' even back then! Thanks, CPNE!
Old 06-25-2003, 04:30 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Thats why you can't find it on your wiring diagram!
