Old 05-22-2013, 10:51 AM   #1
Rufton
C10 C1000 1/2 ton Steering Advice
I'm interested in any steering advise, specifications, interchange, part numbers, tools, thread size, etc applicable to 1960-66 C10 2WD.
I need a Pitman Arm for 1966 GMC C1000 1/2ton 2WD. From pics MOOG-K6086 looks correct. Some specs claim K6086 fits 1960-66 chevy but only 1960-65 GMC?
Does LMC have good pitman arm brand?
PerformanceOnline has one for $39.99.
Don't know if low quality knock offs are out there?
Do pitman arms for newer trucks have same splines but different drop/length/clock?
I may go ahead and replace idler for good measure. Prices vary widely. Parts geek 13969-07063210 is only $17.75.
Rufton is offline   Reply With Quote
Old 05-22-2013, 01:04 PM   #2
tincan1966
tincan1966's Avatar
Re: C10 C1000 1/2 ton Steering Advice
Just my opinion, but steering and brake parts are not the place for the cheapest parts/knockoffs you can find.
Autozone.com has some competetive pricing and I believe AdvanceAutoParts offers discount codes if ordering online.
tincan1966 is offline   Reply With Quote
Old 05-22-2013, 01:20 PM   #3
Rufton
Advance has MOOG K6086 $116.99 for 1966 chevy. No exact fit for 1966 GMC. Maybe a try and see thing.
Old 05-22-2013, 02:36 PM   #4
tincan1966
tincan1966's Avatar
I found an interchange for a Rare Parts number 20109 which does list the part as fitting 1963-66 Chevy C10 RWD and '62-63 and 65-66 GMC C1000RWD.
Maybe that ifo will help you?
Old 05-22-2013, 05:49 PM   #5
Rufton
Thanks. Those GMC years are strange. I'm betting chevy and gmc is same.
I separated pitman arm from centerlink w/ AZ loaner puller tool.
Nut was 1 5/16" and came off w/ 2' cheater bar.
I've yet to pull pitman arm from steering shaft because I don't have a 2 1/4" throat puller. AZ doesn't have 2 1/4" puller either.
Old 05-22-2013, 06:09 PM   #6
tincan1966
tincan1966's Avatar
They should have a pitman arm puller.
I agree and would venture to guess it is the same arm. It also fits C20, and C30 models.
Old 05-22-2013, 07:04 PM   #7
66Submarine
66Submarine's Avatar
RE: buying parts, try Rock Auto. Watch the shipping, but there are lots of good prices on closeout stuff there; regular prices are pretty good, too. Also always a 5% off thing floating around on the net. Autozone/Advanced sell the cheapest crap they can get, they just charge more for it. Some stuff is OK, but most of the time the online dealers have the same for a lot less IME. An example: A lower ball joint for my one ton. Raybestos for $14.32, or "Duralast" for $27. It seems everything at Autozone/Advanced is "special order" anytime I need it, anyways. That, or it doesn't exist.
66Submarine is offline   Reply With Quote
Old 05-22-2013, 09:39 PM   #8
Rufton
Your right. I went to AZ across town and they had large pitman arm puller and it worked great. Did take a fair amount of elbow grease.
Old 06-01-2013, 06:49 PM   #9
Rufton
Anyone have 66 chevy gmc pitman arm and idler arm torque specs?
Old 06-03-2013, 07:07 PM   #10
Rufton
FYI.
66 chevy pitman and idler arm fit the 66 GMC truck.
