05-22-2013, 12:30 PM | #1 |
Upper Shock Bolt 1986 C10
I was doing a rear end swap this weekend and encountered a problem with the bolt that holds the upper part of the shock to the frame. First I sprayed some liquid wrench type of stuff and waited a while before turning the nut. When I went to loosen the nut it broke right off... Where abouts can I find that particular bolt so I can finish the job?
PLEASE HELP Once I get a new bolt, Ill just need to secure the upper part of the shock and fill the housing with differential fluid, bleed the brakes and test drive!!
-Samuel "Knowledge Is Power" |
05-22-2013, 09:04 PM | #2 |
67-72 parts collector,…
Re: Upper Shock Bolt 1986 C10
Your local auto parts store shoould have them.
