Old 05-22-2013, 02:12 PM   #1
nickbwilson
what stall to run
hey guys I have a 5.3 i'm running a ms3 cam from texas speed with a f-body accessories i have 3:73 gears in the rear my question is what stall should i run just for cruising i'm not gonna take my truck to the track its simple a show/ cruiser with in town driving and some high way any suggestion would be great thanks
nickbwilson is offline   Reply With Quote
Old 05-22-2013, 04:02 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: what stall to run
That cam has less lift but more duration then the cam I run on my 6.0 with a 4L85e and 3.73 rear end. I have a 3000-3200 stall convertor that winds up bring closer to 2700-2800rpm. In your case I wouldn't order anything less then a 3500 stall with lockup.
My convertor is loose as a goose in "normal" driving but yet when it hits OD...the slip is gone which is great for cruising at 2000rpm or whatever. Just have to be above 40mph or so...or its gonna slip. Keep in mind they make more heat and you will need a trans cooler or improved trans cooling capability. Stock stall the trans hardly got over 165* or so, usually less. Runs closer to 180*-190* range now... w/o leaning on it.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-22-2013, 04:22 PM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
I'd put a 3600 stall lockup Yank or Revmax in it.
Revmax makes a nice converter...been holding up to a ton of nitrous LS abuse and not missed a beat. Something like half the price of a Yank, also.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-22-2013, 05:34 PM   #4
68GMCCustom
wow those are cheaper then most. I'm happy with my Circle D but if I need another convertor for something else in the future I'll give these guys a try.
Kurt -
Old 05-23-2013, 01:04 PM   #5
Jon01
Jon01's Avatar
Mine's getting Revmax's cheapo 3600.
Circle D, Yank, FTI, any of the big brands that advertise over on tech are good stuff.
Avoid TCI, B&M and the like.
With a 5.3 and that cam you're going to want a fairly loose converter. I'll agree with the 3600 recommended above. Without it you're going to have a hard time getting it to roll the tires over.
Jon01 is offline   Reply With Quote
Old 05-24-2013, 08:43 AM   #6
nickbwilson
Thanks guys for the advice i ordered the 3600 FTI from jegs so we will see how she goes when it comes in
