PS conversion & steering angles
So, following CPP's directions as best I'm able, the pitman arm on my steering box doesn't sit parallel to the ground - it has a little tilt to it, which you can also see in a slight upward tilt of the input shaft.
Is this normal / correct / OK? Or is this bit of angle going to cause problems I haven't yet imagined? If it's cool, I'll drill the other two holes and finish mounting the box. If not... more work with the die grinder to make things sit properly. |
Re: PS conversion & steering angles
If the box is centered after turning the wheel/shaft lock to lock the only issues you will have are that the drag link may be too long or too short and that you will have a tighter turning radius on one side than the other. Unless you get in a tight spot you seldom turn lock to lock on the wheel anyhow so it shouldn't be a big issue. The drag link thing may be a big issue though as it will take an adjustable drag link to correct that.
