Old 05-22-2013, 03:28 PM   #1
cantada
In cab gas tank mount pics
Does anyone have ( or can take) good pics of the stock, in cab gas tank mounts? The Po hacked mine out with a torch right before where the two bolts that attach the mounts to the floor are supposed to be. there are pics of it in my build thread. I will have to acquire the tank straps but will have to make the rest of the mount, unless some has some and could PM me. I want to get the stock experience before I start upgrading as I have never actually driven my truck yet ( was originally sold before I got my license). Thanks in advance, u guys are the best
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=518877
cantada is offline   Reply With Quote
Old 05-22-2013, 03:48 PM   #2
1963c-10
1963c-10's Avatar
Re: In cab gas tank mount pics
I think I have a pair in my parts 61...cover shipping and they are yours. Ill look today if I can get by, tomorrow at the latest.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-22-2013, 04:10 PM   #3
WhippinSaw
WhippinSaw's Avatar
hey cantada, bonehead did a in cab gas tank reinstall. Check out his thread on it. http://67-72chevytrucks.com/vboard/s...d.php?t=563543 and http://67-72chevytrucks.com/vboard/s...gas+tank+mount Good Luck
WhippinSaw is offline   Reply With Quote
Old 05-22-2013, 05:40 PM   #4
cantada
PM sent. Thanks for the link to the thread. I need basically the same pieces as what was welded back on in the last pic on that thread. Looks like ill have to find a used pair, bit much to fab up from scratch. :-). Thanks again guys!
Old 05-22-2013, 09:30 PM   #5
billd5string
billd5string's Avatar
Here's some pics of mine, I hope that helps.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 05-22-2013, 10:20 PM   #6
Brown62
Brown62's Avatar
You probably know but these are welded and bolted. There is a square nut captured under a bracket on the side next to the door for the rear cab mount bolts.
Brown62 is offline   Reply With Quote
Old 05-24-2013, 08:41 AM   #7
bmur66
I am in the same boat as you. I am re-installing an in cab tank. Previous owner cut and ground out the tank saddles as much as he could. Also gone is where the straps go thru brackets mounted on the back of the cab at the top of the tank. What really sucks is everything now has dynomat on it.
Haven't really got into working on it yet but I got a used set of tank saddles from http://4-5-6chevytrucks.com/. Very reasonably priced. I plan on bolting them in.
Not sure how I am going to attach the tank strap brackets to the back of the cab. I was thinking that I would make some custom brackets and rivet them into place because it is all freshly painted and I don't want to ruin that by welding them in. Anyone have any better ideas?
bmur66 is offline   Reply With Quote
Old 05-24-2013, 01:30 PM   #8
cantada
I emailed 456trucks from their web site but have not gotten a response as of yet. Hoping someone has a set of these laying around that I can get my hands on.. Dying to drive this thing for the first time
