Old 05-22-2013, 04:48 PM   #1
bryce6horse
bryce6horse's Avatar
86 k20 transfer case
how do i tell what transfer case i have? the tranny is a th400. i want to change the oil in it when i do the differentials.
bryce6horse is offline   Reply With Quote
Old 05-22-2013, 04:50 PM   #2
bryce6horse
Re: 86 k20 transfer case
i dont know if i have the 205 or 208
Old 05-22-2013, 05:45 PM   #3
LONGHAIR
It should be easy to tell them apart.
The 205 is cast iron and the slip-joint will be in the driveshaft itself.
The 208 has an aluminum case and the driveshaft just slides into it, like a two wheel drive transmission.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-22-2013, 06:49 PM   #4
obijuan
Factory is an aluminum 208. It takes atf.
With the introduction of the np208, regular cab k30, np205 equipped trucks were changed to slip yoke assumingly for continuity reasons. Whereas crew cab and cab n chassis trucks were fixed yoke.
obijuan is offline   Reply With Quote
Old 05-22-2013, 09:27 PM   #5
Mike C
Mike C's Avatar
FWIW, the original 205 t-case on my '86 K30 uses a one piece driveshaft. Not sure what time period they changed that, but know it's possible. But I don't know that I've seen many 3/4 ton auto trucks that had NP205 in them so as others mentioned, should be a 208. Pictures help BTW when asking questions like this...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
