Moderator
![]() Join Date: Dec 2012
What's up with my trailing arms?
After looking at many pics of projects in this section, I realize that there is something strange going on with my truck's trailing arms. Mine have space between the two halves. Didn't realize this was not correct. Also, I thought that the stuff in the space was just rotted wood debris from the decayed bed, but after getting a closer look with the bed off, I can tell it is metal. I have no idea why that would be in between the two halves of the trailing arms.
Not sure what to do here... Here are the scenarios that I can think of: - do nothing - try and knock that strange metal out of there and squeeze the halves back together, then bolt or weld - start shopping for a pair of arms Thanks for any thoughts. Here's the pics: ![]() ![]() ![]() ![]() |
Re: What's up with my trailing arms?
looks like you need to find a new set man!
or start drilling and bolt them back together
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
Who Me?
Yea, that crap is not supposed to be in there.. It looks like rust build up.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
I have 2 sets if your interested
Moderator
Thanks, sent you a PM.
I really don't think that the stuff in between the halves is rusting OE metal. The arms look good from the sides. It's like someone jammed it in there... a long time ago. I'll see if I can knock some of it out. |
Enjoy your truck
Mine started doing that too (original Canadian pieces). It was rust that was spreading them apart so I replaced them.
The wood is probably desbris that fell down from the bed floor (or the bed floor itself). Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
![]() Join Date: Oct 2012
Time to replace those truck arms. The sides should be in contact but them are bout ready to fail and I doubt boltin em up will be a long term fix.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Folks in rusty areas of the country call that rust jacking. When two tightly joined pieces of steel rust, they wedge apart like that.
Posted via Mobile Device |
Mine were the same way. I also thought it was some sort of wood. Just rust and dirt. The u-bolts and spring cup bolts are also in there and they were almost rusted into. Bad design.
![]() Join Date: Mar 2012
Jay , have to agree with everyone above here, Replace them! Only problem is to find a good set around this part of the country.
I have never seen a set of trailing arms look like that, must be all that salt in your diet, luckily its illegal here to salt.
Moderator
Brought this truck up from Arkansas... found out that it lived in Wisconsin for most of its life
#13 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I think some bondo would fix it!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#14 |
Time to replace them
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#15 |
Chevy addict
Welcome to the things we deal with in the midwest
