Difference btween a 2wd and 4wd frame, reason inside
Have a clean 64 gmc crewcab. Have some porterbuilt stuff. Want to stretch the frame and add trailing arms. What is major differences besides the lack of the kick in the rear section of the frame over the rear axle? Front section the same, just without the mounting holes? My 4x4 frame is PERFECT and for sale on here, just can't get rid of it, figured it might be easier to stretch this than cut the truck up while its together and running, 2wd. i'm building a 2wd.
It is a 61 Apachche std cab long bed frame. Thanks Last edited by Novalicious; 05-23-2013 at 06:38 PM. |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Difference btween a 2wd and 4wd frame, reason inside
so you have two 63-66 LWB frames, one is a 4x4 frame and the other is 2WD, right?
I didnt think there was any difference other than the cross member for the transfercase, oh and the axle mounts.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
