20 inch rim and tire combo
I know this is a repeat question but, I have to ask anyway.
Will a 20 inch rim with a 35 offset, 6.13 backside setting and 245/40/R20's work on our trucks? http://www.tiresbyweb.com/tbw_wheels...dex=1&Choice=2 |
Re: 20 inch rim and tire combo
it probably will with some large wheels spacers. 6.13 BS is pretty big. the tires will fit in your fenderwells for sure, i have 265/50/20's all the way around with a 4.5/6 drop. no rubbing. i had to put a 1.25in spacer on the rear to clear the inner fenders but i have a 5.5in BS. how wide are the rims? if they are like 11 or 12in's wide with that big of a BS, it could be a real struggle to make them work. is there any way you can test fit them before buying?
'67 2wd LWB 350/4speed. |
the rims are 8.5in wide. I want to go with the same size tire all around. The rear of my truck has a c=notch and 2in drop blocks as well as air ride and the front is just 2.5in drop spindles so far. Eventually the front with get air ride as well
