Serpentine conversion problem
In the process of converting over to the 96 and up style serpentine brackets. Went to test fit the ac compressor bracket and it won't work. Interferes with the valve covers. Didn't really realize the valve covers I have we're tal but I am hoping they are. Quick measurement showed them to be 3" tall. Any ideas in replacements? These things weren't cheap either.
Re: Serpentine conversion problem
any help or ideas? LOL
Why dont you shave the bracket to clear the valve cover?
Posted via Mobile Device |
I am going to try and do that this afternoon. I can shave a good bit off. Only thing i am minorly concerned about is then mounting the compressor. I think the back end of the compressor is going to interfere slightly with the top of the covers. I might be able to shave down the compressor just a tiny bit as well. Would there be any issues with stacking a couple of washers under the mounting posts for the compressor to raise it just a slight amount? Surely the belt can absorb the pulley being raised a 1/2" or so.
In the Forgotten far North.
![]() Join Date: Jul 2007
Maybe dimple the valve cover as well for clearance if at all possible?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Will it fit on he other side? That is they way mine is set up and I have plenty of room. I'm using the GM performance set up if that helps.
Dan 83 Chevy K10 Scottsdale, ZZ4, TH700r4, 4.10, 33" |
Victory! Lol. Have to touch up the paint of course.
Posted via Mobile Device Posted via Mobile Device |
| Bookmarks |
