Old 05-23-2013, 10:03 AM   #1
WhippinSaw
WhippinSaw's Avatar
broken wiring harness mount clips
Several of my plastic clips that support the wiring harness have cracked. My fix was to trim the cracked pieces off, drill a new hole in the orginal tab, and mount with a nylon rivet I bought at autozone. I bought 1/4" rivets and 5/16" rivets to cover the different size holes and trimmed the top of the rivot mount to hide behind original clip. I used a metal screw to stand out but if you use the black nylon screw it blends in nicely.
WhippinSaw is offline   Reply With Quote
Old 05-23-2013, 10:33 AM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: broken wiring harness mount clips
Nice mod! I like the fact that you used easy-to-get parts that don't cost much money. I've seen guys use Adel clamps, but to me, they stick out too much. Wiring is one of those things that you can spend so much time on, but when it's all done, you really don't want it to be seen. I always try to make sure the harness is freshly wrapped, routed cleanly and safely, and tucked out of sight whenever possible.
I love to see simple mods like this. Nicely done!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
