05-23-2013, 11:09 AM | #1 |
Rear shock mount
Hey guys I was wondering if I can relocate the top shock mount on my leaf spring truck. It has a hole already. If I move it to the front hole it will give me a better shock angle since I lowered the truck.
What do you guys think? Posted via Mobile Device
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
05-23-2013, 11:17 AM | #2 |
Re: Rear shock mount
Drill it out with a step bit and use a stock shock mount, my new Monroes came with one each. Make sure to get a fine thread nut that threads all the way down from Ace Hardware or the like (the ones that come with the mounts stop) and use a lock washer. It really helps, did this on my leaf truck after a flip/drop.
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
05-23-2013, 11:24 AM | #3 |
That was exactly what I was going to do. The new shocks in the picture are Monroes so I have the mounts. Did it improve the ride? Also did you cut down your stock bump stops are get new? if new what kind?
05-23-2013, 11:48 AM | #4 |
Ride was definitely better. Originally I cut down the bump stops by one inch but now I'm using button bump stops from the flip kit. I used the step bit and some 3 in 1 oil to cut a hole in the frame for the button bump stops over the flat part on the axle that you see in front of where the factory bumps are.
05-23-2013, 12:45 PM | #5 |
i would check the shock to see what the length of travel might b in that new location// to me it looks as tho you might have a problem with it bottoming out and might really need new shorter shocks
05-23-2013, 12:51 PM | #6 |
Cdowns has a good point. I forgot to ask, are you running shorter shocks? I used the stock front size Monroes.
05-23-2013, 01:06 PM | #7 |
They are shorter than the stock ones just can't remember how much. But I will definitely check that. Thanks
05-23-2013, 04:56 PM | #8 |
Well I have about 2 inches of travel in the shock and 3" in the suspension. So I guess I will get new shocks. Any ideas on why I should use?
05-24-2013, 08:54 PM | #9 |
Ok guys here is what I did. I drilled out the 1/2" hole to 5/8" installed the new upper front shock stud mount and took the front shocks off and installed them in the rear. Took it for a ride and it was nice.
05-24-2013, 08:56 PM | #10 |
So I cut the old stud off.
