another t-5 question
i know the t-5 swap is everywhere on here but i have not found an answer to my question yet .. i have a 66 chevy 1/2 ton with a 250 six , i want to do the t-5 swap .. it will be an everyday driver , it will pull a small trailer or boat from time to time " in other words she will be used as a truck ...
Re: another t-5 question
I would look for a V-8 t-5, don't count out Mustangs. I used a s-10 tail shaft to move the stick forward. The torque rating is low on these the aluminum housing being the weak point.
Head over to Tremmic web for ideas. I have pictures in the projects and builds, also on cardomain follow my link on signature.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#3 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Though my t5 came from a Trans AM 1985, still on flat bed when the yard pulled it, running the serial brought out a mustang code. I might be wrong but check the ears. Aftermarket bellhouses can also be used. Like I said refer to the Tremmic web.
yea i was told somewhere in the early 90's tremec started putting out the t-5 and it had a ford bolt pattern even in the chevys they used a ford bolt pattern on the trans and the bell housing was chevy pattern . from what i understand i need a 86 to 90 model t-5 with mech.speedo ... and if i dont want a adaptor plate and want to retain the 10 spline orignal clutch in my truck ,,, all i need is a camaro t-5 with a s-10 tail shaft and a late 80' to early 90's jeep t-5 in put shaft ... it is identical spline to my orignal 250 .. then i will have a frankintrans ...lol.... but it will slide right in .. is there a way to find out what speedo gear i need before i install the trans ?
#7 | ||||
Things to consider - The GMC S15 truck is the same as the S10 and had the T5 during the same years. - The adapter plate costs around $150. Count that into the total cost of the tranny if you go with the S10 or S15 tranny. - I was told by a tranny shop that the Ford T5 gear sets can be swapped into the Chevy cases but I have not verified this at all. In other words - you can run a Chevy case with all FORD gears inside. You just need to remember that the WC case needs WC gears and the NWC needs NWC gears. - Autometer now makes a GPS speedometer drive. You don't hook anything up to the tranny at all. You just hook their GPS device to the electronic speedo in your dash and calibrate it. That's it. Unfortunately it doesn't help those of us who want to keep the original cable drive speedo. - Please visit my website and review the info and pictures in the T5 Info Page section listed at the top. I have tried my best to only give info that can be verified. The web is full of mixed info and much is unreliable and often just plain wrong. ![]() ![]()
