05-23-2013, 01:05 PM | #1 |
fuel gauge issue
I know this issue has been beat to death on here, but of all the posts I have read I have not seen any where the issue is actually the gauge itself. I have a 1972 C10 that has had a nonworking fuel gauge since I purchased the truck. Since then I have added an aftermarket fuel tank underneath the bed and new sending unit and replaced the fuel gauge resistor. The fuel gauge still does not work. I pulled the brown wire that goes to the sending unit and grounded it. The gauge goes to empty when I open the connection the gauge goes to full, not all the way to 3 o'clock. When hooked up to the sending unit with a full tank of gas the gauge will read 1/4 full. I borrowed a variable resistor and hooked up to the gauge in place of the sending unit, at 90 ohms the gauge reads 1/4 full and goes down from there as resistance decreases, and will go to empty when grounded. Is there something I am missing? At this point I am about to order a new gauge and was just making sure I didn't miss anything before I do.
05-23-2013, 07:06 PM | #2 |
Re: fuel gauge issue
Sounds like the gauge and wiring are good, you need to test the sending unit. Remove the sending unit from the tank with the guage wire still connected either touch the body of the sending unit to the frame or run a ground wire to it. Then, actuate the arm of the sending unit with the key on and see if the gauge moves. If it moves, that means that your float on the sending unit may be bad or something inside the tank is restricting the arm to move, like a baffle. If the gauge does not move in the above test, make sure the sending unit and gauge have matching ohm ranges. Most are 0-90 ohm, but I think I've read that some gauges may be 0-30 ohm.
Posted via Mobile Device |
05-23-2013, 07:44 PM | #3 |
Proprietor of Dale's Corner
I think it's the gauge. At 90 ohms should read full if I remember correctly
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-23-2013, 07:55 PM | #4 |
As mentioned, at 90 ohms resistance the gauge on the dash should read full.
Before replacing the gauge make sure that the cluster is properly grounded. Although I am sure that the gauge unit can go bad, outside of bad resisters I have yet to see a bad gauge. I ended up running a separate ground wire to the cluster housing on the last problem because the "clip" on ground wire would not ground the cluster. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
05-23-2013, 08:02 PM | #5 | |
05-23-2013, 08:25 PM | #6 | |
I'm not sure I follow your reasoning. I hooked up a variable resistor, it mimics a sending unit. The gauge does the exact same thing as it was doing with the actual sending unit. If the gauge was good wouldn't it work correctly with the gauge test variable resistor hooked up to it? Not only that the symptoms are the same as when the stock tank and sending unit were in there. I'm having a hard time thinking the stock sending unit the new sending unit and the variable resistor are all giving the same bad readings on a good gauge. I would think it has to be something in the dash wiring, the gauge resistor, which is new, or the gauge itself. |
05-23-2013, 08:29 PM | #7 | |
05-23-2013, 08:40 PM | #8 |
One of the screws on the circuit board make contact at the cluster and just follow that around to the plug to figure out which pin it is. I don't remember which pin it is on the plug off hand.
05-24-2013, 09:36 PM | #9 |
I grounded the dash as mentioned above and it's working. I don't know that I would have ever thought of that on my own. Thanks.
