Old 05-23-2013, 01:44 PM   #1
lazypineapple
lazypineapple's Avatar
power steering vent ?
Does a power resivor need to vent ?
My system is Mustang II powersteering
Tbird Rack
aluminum Steering pump (Maval Type)
9" tall aluminum resivor from Speedway
the return line to the tank is about 1/2 way up. i fill to alittle over it.
I notice when i ck level after driving, i was getting a push of air when i open the cap to resivor.
I was afraid that it might blow a seal.
So I drilled a tiny hole in the top of the cap 1/32.
no more pressure sound when cking hot.
but now.
the cap is kinda messy from a small amount of ATF coming out the hole.
if i drop the level below the return outlet in the tank, that causes aeration of the fluid and I get a wining noise from PS.
There are no baffles in the resivor.
so ? if a vent is needed, i would have to figure a way to baffle.
if no vent is needed, i can just plug up the hole and don't worry about that small amount of presure build up I here when cking hot.
lazypineapple is offline   Reply With Quote
Old 05-23-2013, 02:17 PM   #2
Bigdav160
Bigdav160's Avatar
Re: power steering vent ?
The cap should vent.
As the fluid heats up it expands.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-23-2013, 02:27 PM   #3
lazypineapple
i dont see a vent in the cap. it came on the tank.
just a rubber seal, kinda like a radiator cap, but no vent system built in.
