Old 05-23-2013, 02:37 PM   #1
SCOOBYDOOBYDOO
SCOOBYDOOBYDOO's Avatar
Oil pan for LS2 ????
What oil pan are you guys using for the ls 2 swap I have heard truck rear sump deep pans or camaro ???
ScoobyDoobyDoo
SCOOBYDOOBYDOO is offline   Reply With Quote
Old 05-23-2013, 03:21 PM   #2
67 chevelle
67 chevelle's Avatar
Re: Oil pan for LS2 ????
If you are not real low the stock truck pan sticks only an 1 1/2 below the crosmember , a muslecar pan is about even with it , cost around 170 on ebay shiped , im in the process of an ly6 , turbo 350 swap right now
67 chevelle is offline   Reply With Quote
Old 05-25-2013, 08:02 AM   #3
68Stepbed
68Stepbed's Avatar
I used an f-body(Camaro/Trans Am) pan. It sits about 3/4" above the crossmember and tucks nicely into the stock crossmember. A Caddy CTS-V pan also works good. The truck pans hang below the crossmember by about 1 1/4" which could catch and hit on dips and uneven surfaces, especially if lowered.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-26-2013, 12:25 AM   #4
short-t
short-t's Avatar
I used the cts v oil pan, works like a charm.
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD.
1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc
short-t is offline   Reply With Quote
Old 05-30-2013, 08:15 PM   #5
SCOOBYDOOBYDOO
Do you have the current part number for the ctsv oil pan ??
ScoobyDoobyDoo
Old 05-30-2013, 09:38 PM   #6
67 chevelle
that number is in this link you should check the whole sight
http://ls1tech.com/forums/conversion...-oil-pans.html
Old 05-31-2013, 04:22 AM   #7
effects66
effects66's Avatar
CTS-V pan. Perfect fit and it's above the crossmember.
_______________
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=556610
1970 c10 LSX (550hp) frame off
effects66 is offline   Reply With Quote
