Old 05-23-2013, 02:44 PM   #1
Chance72
Chance72's Avatar
Stepside to Fleetside and Shortening?
Alright guys, I've been looking to trade my stepside for a fleet and havnt really came across any deals. A guy just contacted me about him having a longbed. It's in pretty good shape, but what would I have to go through to get the bed shortened. I wouldn't even know where to start. What kind of price range will a shop say the work will be? I have metal skills and all and if i think I can do it, I'll probably try but would probably more like a pro to do it. Thanks guys
1963 Longbed Stepside All Original (Sold)
1994 HUGE Lifted Two Door Blazer (Sold)
1972 Short Step 305 with 3 speed auto (Sold)
1965 C10 Short Step 327 with 350 turbo trans (Sold)
1986 GMC Short Fleet 327 with 350 turbo trans
Chance72 is offline   Reply With Quote
Old 05-23-2013, 04:01 PM   #2
sickboy_1456
Re: Stepside to Fleetside and Shortening?
I debated on the same thing when I shortened mine. The hardest part is finally building the guts to cut into it. Once I finally went for it...it wasn't that bad at all. Just measure, measure, and measure again. Then cut. I bought some cheap panel clamps from Harbor Freight, got it lined up and started tacking. Had some gapping issues from a few out of line cuts, but nothing a little patience and a few more tacks couldn't fix. Just take your time and knock it out. Easily done over a weekend.
sickboy_1456 is offline   Reply With Quote
Old 05-23-2013, 04:50 PM   #3
billd5string
billd5string's Avatar
Do you have any pictures of that? I'd love to see how it came out - it sounds like a cool project.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 05-23-2013, 07:54 PM   #4
sickboy_1456
Here's a few that I have on my phone. Nothing professional, but it came out pretty good once the welds were ground down, etc.
Old 05-23-2013, 07:56 PM   #5
sickboy_1456
One more...
Old 05-23-2013, 10:19 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Looks good.
I have a longbed I want to do.
Did you run into any unexpected issues?
Any tips?
66 C20 Service Truck:
Old 05-23-2013, 10:27 PM   #7
Chance72
Chance72's Avatar
It seems like its gonna be a tuff job for me... Ive got some skills but I don't know if Ive got the guts to trade my step bed for the longbed then do it and mess up then im out a bed. Do any of you guys know what an average price a shop would put on cutting a longbed?
Old 05-23-2013, 10:29 PM   #8
Chance72
Chance72's Avatar
Do you have any more pictures of the process? And like LostMy65, any problems or tips?
Old 05-23-2013, 11:01 PM   #9
sickboy_1456
I basically just took some good painters tape and laid it down about 3" from the forward stake pocket down the side of the bed. Keeping it as straight as possible. Then measured exactly 12" from the edge of the tape line and laid down the second strip of tape. Make sure you have 12" all the way down. Adjust your tape as needed. Do the same for both sides of the bed. I used a saw zaw to make my cut, but its a little tricky to get a straight line. Take your time cutting down the panel. Follow your tape line as best as you can. Remove the section cut out and discard.
Then work your way to rear of the bed. I measured 3" from the rear stake picked and laid my first tape line. Measure 8" and lay down your second tape line. Then cut. Again, the key is measuring over and over again before you cut.
Once everything is cut, grind down any burrs or crooked spots in your cut. Then bring the pieces back together. Having someone to help line the panels up goes a long way. Clamp in place and place a few tack welds. Double check the body lines and continue tack welding. Be sure to jump around between tacks to ensure the panel doesn't warp from the heat. If it does, you can bang it out with a hammer and dolly, but try to avoid it. I wish I had more pics, but this is pretty much how it went. Like I said, just take it slow and don't drink too much!!!
Old 05-23-2013, 11:36 PM   #10
Chance72
Chance72's Avatar
Thanks for that info. I'm gonna have to really think it through. What do y'all think? I want a fleetside, should I try my luck and wait for a short fleet somewhere or should I get this longbed and cut it? I'm only 16 so the drinking really isn't a problem for me lol but I still don't know about it
Old 05-24-2013, 03:19 AM   #11
LostMy65
LostMy65's Avatar
The question is; how much does this longbed cost? Any more than $300 and I'd be really apprehensive. Don't let the anxiousness of wanting it now push you to do something if your not comfortable.
Old 05-24-2013, 07:42 AM   #12
Chance72
Chance72's Avatar
I would be trading my short stepside bed for the longbed fleetside. My stepside has some usual rust down lower on the bottom of the fenders, i dont think the longbed has that much rust. Heres the only pic i have of it right now...
Old 05-24-2013, 12:23 PM   #13
Chance72
Chance72's Avatar
What do yall think of the longbed? It looks pretty nice to me. And I know how to barter alot so I could probably get something else in the deal, like the trim for it and to the front.
Old 05-24-2013, 01:44 PM   #14
faribran
i think that longbed looks like the perfect candidate.......... i say run with it.
faribran is offline   Reply With Quote
Old 05-24-2013, 02:01 PM   #15
Chance72
Chance72's Avatar
I'm gonna be going to the yard today if I can and see if there's any shortbed fleets out there. Maybe I can talk to the guy at the yard and instead of me buying it I just trade him the stepside I have now? Lol if all fails I'm gonna have a huge project on my hands. What welders are you guys using to weld to the metal? My friend has a Hobart 190 welding machine, I don't know if his will work for the thin metal or not. Any info on this?
Old 05-24-2013, 10:53 PM   #16
Chevy Fleetside
Chevy Fleetside's Avatar
I think i will be taking on a long to short bed cut. I have two short beds and if I take both I can get a decent one but I need two of them. I was selling the long bed but it is pretty nice so I think I will cut it down and make it a short bed. Just takes alot of time.
I will take pics but I just don't know when i will get to it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-25-2013, 10:54 PM   #17
Chance72
Chance72's Avatar
Well i went to the yard yesterday and found a sweet short fleet. No rust, small ding on top, and what i like is whoever had that truck put some kind of rubberized paint on it so if i peel it off the original white underneath looks pretty good! Guy said he wants 550 for it but would like to see my stepside and can trade for it. Woohoo!
Old 05-26-2013, 04:18 PM   #18
Chance72
Chance72's Avatar
This is the truck that has the bed I might be trading for...
