A day late and $1 short...
Can We Talk About Wheel Bearings and Grease?
I recently replaced my front brake rotors and wheel bearings in an effort to calm vibration. Combined with re-balancing my wheels and tires my vibration was reduced to nearly zero. After 350 miles, a slight vibration has returned. Not nearly what it was, but it is there at about 60-62 mph. I checked the front wheels and found that there is some play in both front wheel bearing; I wouldn't call it slop but more like endplay. I used Timken bearings and the part store brand grease. I did not remove the existing bearing races, but simply installed the Timken bearings and set the Timken races aside. At this point my suspicions/questions are: 1) Should I have swapped the bearing races, is it a big deal? 2) Is it possible that the wheel bearing grease is insufficient and if so is there grease that stands above the others? Let me know what you know... Thanks in advance!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
member #16
![]() Join Date: Dec 1999
Re: Can We Talk About Wheel Bearings and Grease?
Yes the new race should be used with a new bearing. New against old does not work very good with tapered brgs. Heres a link to timkin brg adjustment.
http://www.timken.com/en-us/solution...gs_English.pdf
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Any grease specified for wheel bearings should be fine. I like Bel-Ray.
Should change race and bearing together because they wear in together. Wheel bearings need preload of a few inch-pounds. FWIR around 25inch pounds but best to look it up. Pitman arm slop, idler, etc are frequent vibration suspects. New tires mask steering linkage slop for a while. |
One thing to add, I also made sure no balance weights were missing and that the wheels are torqued correctly.
#5 | ||
#6 | |
#7 | |
I feel better using the factory matched race/bearing combo. |
Using the races in the rotor is OK. All A3/A5 etc bearings are made to same spec.
A little loose is OK with roller bearings as opposed to tight, tight and you will loose the bearing quickly. I don't suspect any vibration to be coming from your bearings. |
i started using synthetic grease in most everything a few years ago
![]() Join Date: Dec 2012
I too switched to Mobil1 synthetic grease. My main concern is Arizona will let the grease dry out quickly. The synth stuff seems to hold up better. It also CLAIMS better heat and water resistance.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
I tried Mobil 1 syn grease and was disappointed that it separated making a mess of my grease gun. I expected it would remain thick.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I swapped to Belray synthetic grease a few years ago. I really believe its worth the expense and effort to find it.
Posted via Mobile Device |
#13 |
'72 service manual spec is 0.008" for bearing endplay.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#14 |
![]() Join Date: Sep 2005
I always use high temp wheel bearing grease
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
