Rear turn signal problems.
I installed a new turn signal switch cause mine was busted up. Now when I turn on the key I have left rear turn with switch activated or not. And when I have the key turned off and hit the brake pedal my dash idiot lights come on. So I replaced the rear light sockets with new and still the same thing. With turn switch in neutral position I have a constant blinking from the pink wire out of the turn switch. Just a thought maybe I should check the brake light switch next?
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Rear turn signal problems.
sounds like a routing issue.
Are you sure you have the correct turn signal switch? Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
When I bought the switch the seller said it was for a car about thatv same year but was the same. And everything looked the same. I saw where some said there's some sorta rod that needs adjusted under the column?
make sure the hazard flasher button isn't hanging up on the column
Found the problem. Here inside the turn switch there were 2 contacts that were toucking
Posted via Mobile Device |
