Old 05-23-2013, 08:58 PM   #1
BlackhillsHD
BlackhillsHD's Avatar
BBC and a TH350 Kickdown bracket?
I have been searching all over on here and can't seem to find what I am looking for. Has anyone had any luck using a throttle rod with a kickdown cable on a big block. I have tried a couple universal ones and a factory one but they all seem to hit the throttle rod at some point in the travel. Any help would be appreciated.
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44
1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt
General Motors Master Certified wrench swinger
ASE certified Master auto tech
Instructor of Automotive Technology
BlackhillsHD is offline   Reply With Quote
Old 05-23-2013, 09:26 PM   #2
72chevyk10
I built it
72chevyk10's Avatar
Re: BBC and a TH350 Kickdown bracket?
i tried messing with mine for a while then just gave up. never did run a kickdown on the th350 after bbc swap.. or the th400 i swapped in for that matter.. 454's dont need it!
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 05-23-2013, 09:46 PM   #3
BlackhillsHD
Lol yes it def doesnt need it, but It would be all that much better with it hooked up. I know it made a world of difference when I hooked it up on the small block.
Old 05-28-2013, 11:17 AM   #4
kwmech
You will have to take a 350 one and fab it up to fit the 454, never seen a t350 behind a big block from the factory
Old 05-28-2013, 02:58 PM   #5
willett
Another Day, Another Dollar
willett's Avatar
be careful or you'll turn that thing into confetti, theres a reason they stuck th400's behind bbcs
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 05-28-2013, 09:08 PM   #6
BlackhillsHD
I tried the 350 one that mounts on the back side of the carburator, it hits the throttle rod. Tried the universal kind that bolts onto the LR bolt. it hits the trottle rod. Does anyone know of a kickdown braket that had an adjustment up and down? I really dont want to have to weld something up if I don't have to. So far no issues with the 350 but I havent been really hard on it. Plus I only have 265's on it so far, so it spins before it does anything.
Old 05-29-2013, 12:21 PM   #7
kwmech
Maybe look into Lokar for a cable and kit
Old 06-02-2013, 12:32 PM   #8
BlackhillsHD
The lokar stuff is nice, but I can do a lot of fab work for what they cost. I think I am going to try and fab something up of my own design. I will post up pics of the finished product.
Old 06-03-2013, 09:01 PM   #9
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Not to rain on your parade, but you might not want to hook that up. It will only increase your chances of destroying your Th350. I have a BBC in my truck and I've already shattered parts inside mine.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 07-20-2013, 10:39 AM   #10
OldTrucksRule
Went with the Lokar set up for my TH400 on the BBC. Worth the bucks because it works great.
OldTrucksRule is offline   Reply With Quote
