Old 05-23-2013, 10:34 PM   #1
rcbildr
rcbildr's Avatar
Setting up my GMC for towing
Earlier this year my girlfriend bought a 26ft Airstream and I really want to use my 1960 GMC to tow it. The problem is, it doesn't have a hitch. My 63 chevy truck has a nice step bumper with a hitch on it. I figured I would swap out the bumper and I would be good to go. I got the bumpers off the trucks and was getting ready to put the bumper from the 63 on and found out it wasn't going to be as easy as I thought....the frame on my 60 is wider...should've known they would be different.
Anyways, what are my options for putting a hitch on my GMC? I haven't had the time to see if I could go out and buy a new one, but I did do some searching for a used one at the big automotive swap meet last weekend...didn't find anything tho. Any ideas/info would be greatly appreciated. Thanks!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 05-23-2013, 11:01 PM   #2
1/2Dozen
1/2Dozen's Avatar
Re: Setting up my GMC for towing
I just installed a hitch on my 66 suburban today. I took it off my 66 pickup so I could also pull an Airstream. I went with the Draw Tite 41001 and I believe it would fit your truck as well but to be safe better check to see if the frame width is the same.
66 suburban
51 Merc 2 door coupe
38 Chevy Business Coupe (gf's)
76 Airstream Sovereign
1/2Dozen is offline   Reply With Quote
Old 05-24-2013, 11:15 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
I used to tow our horse trailer and our Shire draft horse with my '63 before I tore it down for the latest build up, and plan to use it to tow after I'm finished. I have a class III hitch from Valley.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-24-2013, 12:38 PM   #4
MikeN
MikeN's Avatar
A bumper hitch is NOT suitable for pulling a 26' RV. In fact, I'm not even sure it's legal.
I've towed an 18' open car trailer with a 69 Chevelle on board behind my 64 C10. I've got a Class III Drawtite hitch with weight distribution bars, and my trailer has brakes on both axles with a Prodigy brake controller. I don't think you ought to seriously consider towing a 26' RV without a setup similar to mine.
JMHO
MikeN is offline   Reply With Quote
Old 05-24-2013, 02:36 PM   #5
Tom66C10
Mike,
Do you have a part number for the hitch? I want to pull my 1972 Buick GS with my 66.
Thank you.
Tom66C10 is offline   Reply With Quote
Old 05-24-2013, 08:38 PM   #6
1/2Dozen
1/2Dozen's Avatar
I agree with Mike, don't trust the bumper hitch to pull that airstream. I would feel uncomfortable pulling anything with it in my opinion. The Drawtite hitch model 41001 is a class 3 to 4 with Tongue Capacity/Tow Capacity : 600/6000 Lbs. I also have the distribution bars along with brake controller. It is the safest way to go.
66 suburban
Old 05-24-2013, 09:19 PM   #7
rcbildr
rcbildr's Avatar
The only reason I even considered the step bumper/hitch combo off my 63 was because I've seen what the truck has towed. The hitch on the bumper is more than just a receiver welded to the bumper, there are braces that go back to frame crossmembers and were welded there too. I got the 63 from a friend I've known since high school, he used the truck to haul his friend's boat around which is a 24ft sea ray...IIRC one of the biggest you can fit on a trailer. Even then I am not too thrilled about the idea...I just haven't been able to locate a hitch yet that is for a frame that's around 42" wide....the 63 and up frames are around 37" wide. Most likely we will use our 85 diesel burb until I can find something that will be safe.
My Projects:
1978 Camaro Z28
Old 05-28-2013, 10:14 AM   #8
MikeN
MikeN's Avatar
Originally Posted by Tom66C10 View Post
Mike,
Thank you.
I'll see if it has a part number on it when I gt home tonight.
Old 05-28-2013, 11:29 AM   #9
MikeS.
MikeS.'s Avatar
Yes the 60-61s have a different width frame.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 05-28-2013, 04:11 PM   #10
MikeN
MikeN's Avatar
My recollection is that DrawTite doe not offer a direct-fit hitch for 64-66 short bed trucks. They offer one for a 64-66 long bed, but there is a frame cross member very near the rear of a short bed truck that requires very slight frame modifications to make the long bed hitch fit a short bed. I had my hitch installed by the local DrawTite dealer, and it was no big deal...two very slight notches on the frame rails and a couple of holes drilled. I've been very satisfied...it's been on there since 1995 or so.
There are several threads on this site, I'm sure, about making the long bed hitch fit a short bed truck.
Old 05-28-2013, 04:55 PM   #11
newbe351
Does a tow hitch affect the spare tire location (assuming the gas tank is still in the cab)?
newbe351 is offline   Reply With Quote
