Old 05-23-2013, 11:54 PM   #1
Evaded
Evaded's Avatar
No High with my AC... What is it?
Been working on my AC, got it all going but have no High? I think its 4 speeds right.. when I try to put it on high it does nothing. AC resistor maybe, or something else? Let me explain better.. when I switch it to high it turns off.
Eric
If I see a Zombie.. Im runnin it over with my Truck.
Evaded is offline   Reply With Quote
Old 05-24-2013, 06:32 AM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: No High with my AC... What is it?
I believe there is an inline fuse somewhere that if it blows out, the high speed stops working.
On Chevelles I think it runs across the firewall but not sure where on a truck. Might be the same place.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-24-2013, 06:42 AM   #3
jjzepplin
jjzepplin's Avatar
Just fixed mine from info on this forum. It was a bad connection at the fuse block on the good fuse. Look for the big orange wire coming from your a/c going into the side of your fuse block and then pull the fuse. I just pushed a good fuse onto the bad one and the fan went on. From there I pulled it all out and fixed the issue.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-24-2013, 08:18 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
When one speed doesn't work, it's usually the switch.
Tom Vogel is offline   Reply With Quote
Old 05-24-2013, 10:25 AM   #5
Wrenchbender Ret
There is a relay on the engine side around the evaporator unit or firewall. This takes the excessive load of high blower off the ign switch & A/C controls. There is a fuse inline on a heavy gauge wire near this relay. Use a test light to trace it. If the fuse is good the relay is probably bad.
Wrenchbender Ret is offline   Reply With Quote
Old 05-24-2013, 01:16 PM   #6
Evaded
Evaded's Avatar
Ok Ill start checking it all out. Thanks everyone for the info... process of elimination now.
Eric (Evaded)
Old 05-24-2013, 05:33 PM   #7
Gene
Gene's Avatar
What ^^^ He said
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 05-24-2013, 05:50 PM   #8
leddzepp
Moderator
leddzepp's Avatar
The relay is your likely cause. They are not expensive and are easy to replace.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-24-2013, 05:53 PM   #9
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
High speed relay
1970 CST K10 350/350/205
Short Bed - Fleetside
Tach-Tilt-A/C-Tow Hooks
Front & Rear Disc Brakes
Front & Rear Posi 3.73 Gears
30 Gallon Stainless Fuel Tank
SOLD 01/18 !!!!!
2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ
70 CST 4X4 is offline   Reply With Quote
Old 05-24-2013, 06:51 PM   #10
RenoKeene
Florida Edition
RenoKeene's Avatar
In the cab under the glove box mounted on the ac box.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-25-2013, 01:47 AM   #11
Hutch
Hutch's Avatar
Evaded,
When I had this problem it was the ground wire from the relay on the inside firewall behind the glove box up high on the passenger kick panel side.
You may have to remove the Glove box liner to see this relay
There is a short ground wire with a ring on the end that goes to one of the bolts that hold the inside heater box to the firewall.
Mine had been left disconnected after some heater service
Easy test just run a ground to the frame from the relay while the fan switch is on high
Fan speed symptoms were:
Low =low
Med=Med
High=Very slow
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 05-25-2013, 07:23 AM   #12
Evaded
Evaded's Avatar
Thanks Hutch.. made sure that was hooked up when I installed my new duct work for AC and glove box. Will keep eliminating above responses. Thanks everyone so much.
Old 05-25-2013, 09:30 AM   #13
Andy4639
Old member
Andy4639's Avatar
Wink Re: No High with my AC... What is it?
I just fixed mine also. I took the switch off and took it a part brushed it real good. Crimped the spade connections really tight with a set of vise grips and put it back together. It's been working ever since.
If the spade connections are loose and wiggle that means heat build up and after a while it want fuction as it should.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-25-2013, 04:56 PM   #14
Evaded
Evaded's Avatar
Hmmm... thanks^
Old 05-25-2013, 07:33 PM   #15
jjzepplin
jjzepplin's Avatar
So what did the trick...? Inquiring minds want to know!
Old 05-25-2013, 10:28 PM   #16
1972RedNeck
1972RedNeck's Avatar
When I got my truck the wire was unhooked and hid up in the dash.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 05-26-2013, 01:08 AM   #17
allchevy58
allchevy58's Avatar
Mine was the switch.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
