Old 05-24-2013, 11:45 AM   #1
FB85C10
Cab Removal?
Im getting ready to remove the cab off my 85 c10 and i started on the passenger side under the firewall area i put my wrench on and my breaker bar on it i slowly attempted to turn the bolt it started to come loose then i heard a snap and then the bolt just started to spin along with the top and bottom bushings along with it, is there a nut welded on the inside of the support for the bolt to bolt into cause i think that the welds broke loose and now it spins and i cant see in the support to see if there is a nut or not. So my questions is there a nut inside the support and how do i fix it and get the bolt out, any suggestions? what is the best way to get these cab bolts out any tricks on doing it or no? Help. Thanks!
FB85C10 is offline   Reply With Quote
Old 05-24-2013, 01:17 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Cab Removal?
there is a nut welded inside the cab frame rail.. you can cut the bolt off underneath and lift the cab off you can cut a hole in the cab floor for access and try to grab or re weld then patch the floor where in nj are ya?? Sayreville here
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
