Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 05-24-2013, 01:30 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
WTB: need a little crossmember piece from someone parting a truck out
It's been missing for about 30 years I guess, but I want the little crossmember wing deal that goes from the upper frame web to the crossmember.
See pictures below. I'm cheap and want something cheap. It's been gone for nearly as long as I've been alive so I can't justify spending a mint to replace it.
My truck is a 78 model, half ton, 2wd with Turbo 350. Not real sure on the interchange. It's a single hump crossmember.
Old 05-24-2013, 02:01 PM   #2
396ci
396ci's Avatar
Re: WTB: need a little crossmember piece from someone parting a truck out
you need 1 or 2? i have several.
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 05-24-2013, 03:47 PM   #3
Tx Firefighter
I just need one. My crossmember only uses one. The left side is where the exhaust and catalytic converter would pass. The brace is on the passenger side. I wish I knew crossmember fitment better so we could verify fitment.
Old 05-24-2013, 05:36 PM   #4
396ci
396ci's Avatar
here is a pic of what i have. this distance on the frame holes is 3 7/8" center to center and the part that goes over the cross member is 3 1/4". this came from a 2 wing style but i have a single 'j' style cross member i can try it on to make sure it will work. just verify the frame bolts are 3 7/8". if this works, how does $16.50 shipped sound to you? thank you.
Brian
XNGH ECV Chapter 58
Old 05-24-2013, 05:44 PM   #5
Tx Firefighter
That price sounds fair and reasonable.
I'm gonna be away from my shop till Sunday so I can't measure until then. I'll measure Sunday and respond back to you then. No real hurry I guess anyway. The Post Office is going to be closed Monday for holiday anyway.
By the way, my crossmember is the J type. That's a good description.
Old 05-26-2013, 12:06 PM   #6
396ci
396ci's Avatar
my 86 had the correct cross member so i took the piece off (no need to measure). have a great weekend and contact me on monday or tuesday. thank you.
Brian
XNGH ECV Chapter 58
Old 06-06-2013, 06:21 PM   #7
396ci
396ci's Avatar
i received the money order and will be shipping the 'wing' tomorrow. thank you!
Brian
XNGH ECV Chapter 58
Old 06-07-2013, 06:26 AM   #8
Tx Firefighter
Thank you Brian. Ill post pictures once I get it all powder coated and installed. I sure appreciate it.
