Need new fan clutch, which one to get?
So the truck likes to run hot at idle or when not moving, and determined the fan clutch is bad(radiator, water pump, thermostat, coolant are all new) It really likes to freewheel. But I'm not sure which one to get between standard and heavy duty. I'm not sure whats even on the truck right now. It's purely a performance truck, no towing or hauling done with it. So I'm leaning toward the standard duty clutch cause I hear its better for performance. But being a truck and not a car, I'm not sure if i should go with the heavy duty because of the heavier weight. Plus, heavy duty is all that is listed when searching online for stock c10 parts.
Any opinions? Thanks. |
Junior Member
Re: Need new fan clutch, which one to get?
What year truck do you have and what engine does it have?
Where have you looked for a fan clutch? Most local auto parts carry them. Also Rockauto is a good place to buy from.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
At the body shop.
Electric fan?
" That didnt make it any newer " " Dont antique the equipment " |
That's what I was going to say make a salvage yard electric kit
Posted via Mobile Device |
I thought about electric, but have never installed one before so I was just gonna keep it simple and cheap and just get a new fan clutch.
78 Big10 454
![]() Join Date: Jul 2008
I bought my standard fan clutch at NAPA. No problems to report.
1978 Chevy SWB C-10 2WD 454/400 |
Be sure and buy a centriguful clutch, it will have a bi metalic spring on the front and dont cheap out.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
go to www.acdelco.com and enter your info or try www.rockauto.com
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
x2 on AC Delco. I replaced mine with ACD a couple of years ago and it runs OK in 110 degree desert heat - all stock 454 C20.
Try: autopartstomorrow.com oehq.com oewarehouse.com rockauto.com gmpartsdirect.com |
#10 | |
![]() Join Date: Apr 2009
Its the "Thermostatic" clutch that is temperature operated with the bi-metallic spring in front. http://www.haydenauto.com/upload/Hay...n-clutches.pdf Desert |
Extreme duty fan clutch app:
1977 C20 2wd 350cid Cooling Depot #11136704 for cross reference purposes. Alex. |
