Old 05-24-2013, 09:29 PM   #1
OregonNed
OregonNed's Avatar
Seat reupholster - opinions sought
This is another of my list of projects to complete that I need some advice on.
I bought this folding seat for my truck to recover, and wondered about an issue I see on it. The springs in the seat look pretty good, but as can be seen in the photography the lower side springs are original one side, but on the other side a section of plywood was attached to the frame, and some sort of "helper" spring(s) were put in place of the regular springs. The spring is packed tightly with some sort of foam, but it is a bit crumbly and deteriorating.
Can this be left as is, or is it possible to get spring attachments to fix this? I'm worried that the addition of the plywood would make seat covering attachment impossible - but maybe this was a legitimate upholsterer fix?
Thanks, I am just not an expert..
Ned
Original springs on one side.
Plywood attached to other side.
Spring(s) attached to plywood and seat.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 05-24-2013, 10:42 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Seat reupholster - opinions sought
I think I would remove that stuff and replace it with the correct springs. If you can find another seat you can rob some of the springs from it. If I remember correctly I used some of the springs from the front edge of an old seat to repair the sides. I don't know if you can get replacement springs from an upholstery shop or not. You would have to check.
LockDoc
Leon
Old 05-25-2013, 01:11 AM   #3
OregonNed
OregonNed's Avatar
Thanks Doc - appreciate the insight!
Old 05-25-2013, 10:34 AM   #4
LockDoc
LockDoc's Avatar
If you look on this page of the LMC catalog
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=46
in the 2nd box, part #4 (30-3124) is listed as an end spring repair RH/LH, (2 required) even though it shows it located in the front of the seat..
LockDoc
Leon
