Old 05-24-2013, 09:54 PM   #1
72chevynoob
Opinions please!
I am putting my truck together for summer vacation. Should I go with a wood bed or steel? If I go wood I need to replace most of the cross braces, including the expensive back one. I do already have marine grade plywood though, in a 10' sheet. My truck is going to be a daily driver during the summer (no 4wd= no winter), and I would lacquer the wood, or bedline both sides of the steel. Which should I go with?
Justin
69 lwb project: http://67-72chevytrucks.com/vboard/s...d.php?t=558011
72chevynoob is offline   Reply With Quote
Old 05-24-2013, 10:12 PM   #2
jocko
jocko's Avatar
Re: Opinions please!
If you have a steel bed, I'd just leave it. If you go with a wood floor, I do not recommend plywood - I'd go with a hardwood. What do you have now? Steel I assume if you are talking about requiring cross brace replacement. if that's the case, I'd probably just stick with steel, nothing wrong with original.
Old 05-24-2013, 11:02 PM   #3
dylan1970
dylan1970's Avatar
I have always liked the wood bed look!
dylan1970 is offline   Reply With Quote
Old 05-24-2013, 11:22 PM   #4
tmc1986
Daily driver=steel bed. Durable and looks great if its lineX'ed or whatever kind of Berliner you want. The wood beds will never hold up like a steel bed.
'67 2wd LWB 350/4speed.
tmc1986 is offline   Reply With Quote
Old 05-24-2013, 11:44 PM   #5
72chevynoob
It is actually a wood bed, I just live in the land of road salt and snow. Why don't you recommend plywood? It is far more durable and less prone to warpage/cracking than hardwood.
Justin
Old 05-24-2013, 11:52 PM   #6
jocko
jocko's Avatar
because of the exposed ply edges along the length. they absorb a lot of moisture, marine grade or not. Hard wood will only have "end grain" at the ends of the boards. But, more importantly, when you cut it and rabbet it to fit under the slats that hold it down, it will very likely splinter. Just not ideal for making bed wood.
Old 05-25-2013, 12:01 AM   #7
72chevynoob
Good point. I just looked up the numbers, and in Canada the prices are fairly similar for wood vs. steel:
Cross sill (3x): $55ea
Bed strips: $120
Rr. cross sill: $55
Bolts: $45
Reinforcement strip: $120
White oak or marine
grade plywood: $150-$180
Total: $655-$685
Complete steel: $600
The local place that carries parts for these trucks is a ripoff, and that is why the wood bed stuff is so expensive, however, I can get the complete steel bed from our local auto body parts store for an ok price, plus they carry Tri-plus, which is supposed to be fairly good quality.
Justin
Old 05-25-2013, 12:46 AM   #8
leftybass209
leftybass209's Avatar
I have always like wood beds better than steel. That being said if it ain't broke don't fix it, that's why I don't convert to wood. If money and time is available to you, then its personal preference. Whatever you choose, good luck!
leftybass209 is offline   Reply With Quote
Old 05-25-2013, 11:23 AM   #9
ole dollor
ole dollor's Avatar
i like the bed wood better, if done right it is far nicer than metal ...
ole dollor is offline   Reply With Quote
Old 05-26-2013, 12:51 PM   #10
72chevynoob
I think I will stick to a wood bed and buy a bed mat for when I have to haul stuff. Thanks for the advice and opinions!
Justin
