Old 05-25-2013, 08:53 AM   #1
lucifer
lucifer's Avatar
undercoat ideas
Just finished blasting all the crap off underneath my 65. Wanting to know everyones ideas/thoughts on undercoating/rustproofing/paint???
Keep in mind I want the benefits of sound deadening as well. Thanks in advance.
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 05-25-2013, 09:18 AM   #2
Sharps40
Re: undercoat ideas
For a frame off job...POR 15 products/coatings under...sound & Heat deadener matting in cab and doors.
Sharps40 is offline   Reply With Quote
Old 05-25-2013, 09:24 AM   #3
Trsmotrhed
Trsmotrhed's Avatar
Re: undercoat ideas
I'm planning on using lizard skin coating. There's a few builds on here using this product and looks great and will do what you're looking for. They also offer a ceramic heat resistant coating. Check it out.
http://www.lizardskin.com/sound-control-insulation.html
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 05-25-2013, 12:06 PM   #4
FetchMeAPepsi
FetchMeAPepsi's Avatar
Re: undercoat ideas
I planned on putting bedliner on all of my undersides after shooting it with DP90. Anything that can get hit with a rock is getting bedliner on it.
Disclaimer: I'm no pro and this is just info I've gotten from other builds.
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 05-25-2013, 01:57 PM   #5
mark 66
Re: undercoat ideas
Ive used this stuff called stutz or something. its like a bed liner and is applied with their gun.sprays out nice.then I used dynamat on the inside.
mark 66 is offline   Reply With Quote
Old 05-25-2013, 02:09 PM   #6
Rufton
Re: undercoat ideas
I like epoxy primer. Good protection in shaded applications. Easy to repair.
I hate removing bed liner and thick under coat.
Rufton is offline   Reply With Quote
Old 05-25-2013, 07:43 PM   #7
MikeS.
MikeS.'s Avatar
Re: undercoat ideas
Rhino lining for me.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 05-25-2013, 08:22 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Re: undercoat ideas
From my experience U-Pol Raptor bedliner obsoletes everything else. It is comparitively inexpensive, easy to apply, and extremely durable.
http://67-72chevytrucks.com/vboard/s...d.php?t=581389
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-25-2013, 10:29 PM   #9
spacedebris
Re: undercoat ideas
x2 on the lizard skin. I plan on using both the lizard skin ceramic coating and sound deadening.
spacedebris is offline   Reply With Quote
Old 05-26-2013, 09:38 AM   #10
vin63
It's Better With Nitro
vin63's Avatar
Re: undercoat ideas
I used the 3M Body Schutz this time around on the underside of my cab and inner fenders. It's the third time I've used it (previous two times were customer requests on the backsides of various panels I fabricated), and it is really easy to work with and use.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-26-2013, 12:34 PM   #11
Trsmotrhed
Trsmotrhed's Avatar
Re: undercoat ideas
How does epoxy primer provide sound protection? Just asking because I wouldn't think it would provide sound protection like one of the coatings mentioned here unless you apply a product like dynamat over it.
63 SWB C10
Old 05-26-2013, 01:11 PM   #12
theastronaut
theastronaut's Avatar
Re: undercoat ideas
Epoxy first, then add undercoating/sound deadener. I like Lizzard Skin. You can also mix up a batch of cavity wax and spray around all the seams and inner channels for extra rust protection.
theastronaut is offline   Reply With Quote
Old 05-26-2013, 02:34 PM   #13
amccomb
Re: undercoat ideas
I am using SEM rust shield on my 66 k10.
amccomb is offline   Reply With Quote
Old 05-26-2013, 03:24 PM   #14
Rufton
Re: undercoat ideas
Your right, no sound protection.
Old 05-26-2013, 07:13 PM   #15
65chevysub
65chevysub's Avatar
Re: undercoat ideas
Definately bedliner. I had a friend who used to own one of these shops, and had him do the underside of my hood, and the gas tank on my old 65 Chevy II. He used the "leftovers" from different jobs, called "slag". It all comes out black so it should work for your truck(s), and it was cheap.
65chevysub is offline   Reply With Quote
