Tight Clearance Fan Blade what are you using?
I'm getting ready to drop my BBC into my truck.
I have an alum. 4 core rad. I need a fan that is light & works well in tight clearance situations. My set up is 4x4 1975 Frame w/ 65 GMC body. No room for a clutch fan, so what ever fan I use will have to be light. I'm not worried about losing power or gas milage. {Pulling Truck} |
Re: Tight Clearance Fan Blade what are you using?
I used a Flex-a-lite Black majik flx-180 from summit in my Durango and the dimensions work well for stock radiator so that's what I plan on next. 3300cfm. Pictures on cardomain under lvphotos on the Durango.
You should have more room up front or are your mounts way forward? I have 3" spacer on fan and still have 3" more from fan to radiator.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 05-25-2013 at 12:45 PM. |
I doubt I have 1 inch. More like a half an inch.
are you running a long or short water pump?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Its a long, I don't have the pulleys for a short set up.
![]() Join Date: Oct 2010
I use the same fan as LVPhotos (Black Magic - 3300 cfm). I have a small block, but moved the motor up so it was closer to the radiator (I have a 3 row alum). I also had to go with a short water pump. Had to buy new pulleys to make it work. With this setup, I have about an 1" left.
You may have to do the same with your water pump and pulley setup
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
6 cylinder 4 blade fan resembles a X. They are pretty flat
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi |
![]() Join Date: Aug 2011
Electric!
http://s994.photobucket.com/albums/af62/ScottAz2/ |
