Old 05-25-2013, 12:15 PM   #1
chevy-fun
chevy-fun's Avatar
shackle/hanger guys come in
i just finished doing a McGaughy's shackle/hanger. i was looking for a 4" drop . i measured all four corners before starting. an it turns out i only got a 2.5" drop on both side. i did leave the leaf spring an shackle bolts LOOSE an jump in the bed an drove around the block a few times. no change in drop. i expected a 3-4" drop. not 2.5", is this something that will settle down later.
1. whats average drop with this kit
2. using stock shock- could that be my prob. even though plenty room still left
here is a few pix
chevy-fun is offline   Reply With Quote
Old 05-25-2013, 02:06 PM   #2
tinydb84
tinydb84's Avatar
Re: shackle/hanger guys come in
Did you replace the hanger in the front as well? I cant see from the pic
I noticed the bed notch is already rusted...did you compare the suspension pieces you replaced? Im thinking your truck already had hangers on it
David
Instagram: myfabguy
Old 05-25-2013, 02:37 PM   #3
chevy-fun
chevy-fun's Avatar
tinydb84 yes i replaced the hangers in front. the truck alread had the c-notches when i bought the truck an also the notch in the bed rail. the truck prob had shackles at one point but were not on the truck. heres some more pix
Old 05-25-2013, 03:22 PM   #4
tinydb84
tinydb84's Avatar
hmmm...interesting lol
When I did mine, my stock hangers where way shorter than yours. Yours dont look aftermarket but maybe they were 1 inch drop? That would be why you ended up with closer to three inches?
David
Instagram: myfabguy
Old 05-25-2013, 06:22 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Looks like a one on drop shackle. Shouldn't come so close to the cross brace from factory
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-25-2013, 07:14 PM   #6
chevy-fun
chevy-fun's Avatar
tinydb84 INSIDIOUS '86 both yall were right i compared it to stock rear end assemble im using for parts. an sure enough it is one inch bigger had i known that i would went with a flip kit. either gonna put back to stock an sell the kit an buy a flip kit. or buy some drop leafs. just sucks spend all that time grinding an drilling rivets out for nothing
Old 05-26-2013, 03:23 PM   #7
tinydb84
tinydb84's Avatar
Go with the flip kit. You can keep half the kit and go with a 5/7 drop if you want.
Drop leafs are so expensive I wouldnt do them unless one of my springs was bad
David
Instagram: myfabguy
Old 05-26-2013, 05:04 PM   #8
chevy-fun
chevy-fun's Avatar
i may just order lowering blocks an do 1" an 2" to fix the chevy lean its real noticable now. will see what happens
