Old 05-25-2013, 03:50 PM   #1
67 chevelle
67 chevelle's Avatar
68 rear change
I have a 68 c10 project truck , its got " one wheel peel " , and 273 gears , I have to upgrade , its been lowered 3-5 , got discs in front , and is getting an ly6 and turbo 350 , whats the best , easiest , cheapest , way , id like to keep the 6 on 5.5 , so gears and a posi are my asumption , who to get them from , truck pinions are longer i think so i cant change to car gears , ive got an 69 chevelle 12 bolt with 331 gears but no psi , i dont think they will interchange , any help would be apreciated
67 chevelle is offline   Reply With Quote
Old 05-25-2013, 07:15 PM   #2
hereinmissoula
Re: 68 rear change
i have similar question... though my 68 c10 is longbox and is 3.73's... need something stronger but don't want a heavy 14bolt, or to weld all the stuff on there, though that might not be avoidable ..............
hereinmissoula is offline   Reply With Quote
Old 05-25-2013, 07:16 PM   #3
hereinmissoula
Re: 68 rear change
actually i was thought you were talking swapping the whole rear, sorry if i hijacked your thread
Old 05-25-2013, 07:46 PM   #4
69GWC
Re: 68 rear change
I bought a True trac locker and new gears from Summit, also bought a master rebuild kit and went clear through the rear end.
69GWC is offline   Reply With Quote
Old 05-25-2013, 08:58 PM   #5
SS Tim
SS Tim's Avatar
Re: 68 rear change
2.73 gears... really? Thoses were not stock in 68. Since you never stated what ratio you wanted its hard to give specific suggestions. But a new posi carrier to go along with new gears and bearings would be the best way.
If you need a stronger axle there were the big block/manual Spicer/Dana 60 axles in C10s (68,69 and 70 for 6 lug). These were 3.54 though and you would probably need to regear it.
SS Tim is offline   Reply With Quote
Old 05-25-2013, 09:19 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 68 rear change
I would advise against using any used diffs and gearsets. Get a new locker or an Eaton posi-traction with a new set of gears to match. If you cheap out on the gears... you'll be rewarded with a noticeable "whine".
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-25-2013, 09:45 PM   #7
67 chevelle
Re: 68 rear change
yes 273's it was a 305 with a powerglide , think id like 342s i know they were very comon later in the 80s trucks , i would switch the whole rear but want to keep the 6 0n 5.5 , just got ralley rims with the patern , is the stock ratio listed in the glove box ?
