Old 05-25-2013, 06:57 PM   #1
draggin49
filthy motor......
Well, I put a can and a half of gunk engine degreaser on it at my house.it loosened up the big stuff.took a small putty knife and scraped off the majority.sprayed it down with my hose but I couldnt get enough pressure.still is pretty filthy.
Suggestions on how to get the remainder off? Im guessing this has been on there for a LONG time.
my brother might be able to borrow a pressure washer from his painting company.
Will the psi of the washer get whats left? Or do I need a certain cleaning agent
draggin49 is offline   Reply With Quote
Old 05-25-2013, 07:06 PM   #2
71swb4x4
71swb4x4's Avatar
Re: filthy motor......
Are you doing that with it warm or cold? I would run the truck down the highway and get it nice and warm, and then try some degreaser and water.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-25-2013, 07:40 PM   #3
Kurt L
Kurt L's Avatar
try easy off oven cleaner i've head and read on this board that works.
Kurt L is offline   Reply With Quote
Old 05-25-2013, 07:40 PM   #4
69GWC
Castro Super clean is the best cleaner I have ever used.
this motor fire wall and fenders were coated with filth real bad but some Castrol super and a power washer cleaned it up great.
69GWC is offline   Reply With Quote
Old 05-25-2013, 07:45 PM   #5
Boog
laying low
Boog's Avatar
That Gunk engine cleaner is some good stuff but the baked on oil and grease may take several applications to remove it. Also in our area the local car washes have an engine cleaner option. It seems to work pretty good too on the normal oil and dirt accumulation. Spray it on a warm engine, let it sit while you wash the rest of the truck, then rinse the engine down. High pressure spray helps alot.
Isn't that Easy Off oven cleaner hard on paint?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-25-2013, 08:05 PM   #6
draggin49
My bad guys, forgot to mention the motor/trans is out of the truck. So I cant run it to get the motor hot.
Itll need to be repainted, so im not worried about eating paint that is on there.
The compartment itself was filthy too
Engine before any gunk
Old 05-25-2013, 08:09 PM   #7
Sicklajoie
The Niner
Sicklajoie's Avatar
I would definitely try to get ahold of a pressure washer.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 05-25-2013, 08:22 PM   #8
Square_78
Square_78's Avatar
Do we need to put a plastic bag around the distributor and carb or anything? Alternator? Want to make sure the truck will start afterwards
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 05-25-2013, 08:25 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Product called "Marine Clean", made by POR-15.
Get it, use it, love it... No pressure washer needed... just time and a garden hose.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-25-2013, 10:03 PM   #10
domeier
domeier's Avatar
Engine patina...
domeier is offline   Reply With Quote
Old 05-25-2013, 10:07 PM   #11
leddzepp
Moderator
leddzepp's Avatar
Gary
X2. 40 years of caked on crap falls off like butter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-25-2013, 10:17 PM   #12
draggin49
Hahah yep engine patina to the max.
I am gonna go do some searching to see if a local place has it in stock.would like to finish it this weekend, hopefully I dont have to order it.
Old 05-25-2013, 10:18 PM   #13
draggin49
Old 05-25-2013, 10:34 PM   #14
71swb4x4
71swb4x4's Avatar
That's a lot of rust preventer on that engine.
Old 05-25-2013, 10:39 PM   #15
Rufton
Kerosene in spray bottle and plastic bondo spreader knife. Cut different widths bondo knifes. Dispose of grease properly or just dump in the gulf like BP . Protect water sensitive bits w/ plastic. Spray bottle pure laundry detergent. Pressure washer. Quickly grease exposed suspension; steering; etc to drive out H2O before corrosion.
Rufton is offline   Reply With Quote
Old 05-25-2013, 10:59 PM   #16
Rufton
I was able to keep factory original paint on motor mount after kerosene, detergent, pressure wash clean. Many other ways work too.
Old 05-26-2013, 09:35 AM   #17
bumwine
bumwine's Avatar
Por 15 marine clean is awesome stuff like they said above. I usually put hot water in a spray bottle to clean the marine clean off. Grease falls right off
bumwine is offline   Reply With Quote
Old 05-26-2013, 10:14 AM   #18
KEL
72 GMC
KEL's Avatar
Love the "NOT TITE" reminder !
KEL is offline   Reply With Quote
Old 05-26-2013, 10:18 AM   #19
brad_man_72
the boat guy
brad_man_72's Avatar
I like purple power, don't get on aluminum or nice paint.
Grab the wire wheel and flapper disc and clean that engine up before you repaint.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 05-26-2013, 03:02 PM   #20
draggin49
Luckily I dont have nice paint or aluminum to worry about
Would using a wire brush before the pressure washer help?
Some of the stuff on the heads seems like its gonna be the hardest to get off.
Old 05-26-2013, 03:21 PM   #21
Lattimer
Lattimer's Avatar
Wire brush, putty knife, any of the chemicals mentioned, and elbow grease.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 05-26-2013, 03:32 PM   #22
Rufton
Thanks; Little better than NOT TIT
Old 05-26-2013, 03:46 PM   #23
draggin49
Im gonna go get purple power or the castrol super clean and a wire brush. Gonna just tackle each area little by little. Then after its been scraped entirely ill apply some more cleaner then blast it with the pressure washer
Old 05-26-2013, 04:12 PM   #24
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
When I'm working on something particularly nasty, starting several day before, I soak it with oven cleaner then pressure wash. Let it dry fully and repeat again as many times as needed until clean. Sometimes it takes me a week and half a dozen soak and pressure wash cycles but the parts are always "eat off of it clean" when I'm done. Only then can you begin to restore, detail, and fix any leaks.
Old 05-26-2013, 04:47 PM   #25
GASoline71
GASoline71's Avatar
I'm tellin' ya... Marine Clean needs no pressure washer, and it won't screw up paint or aluminum. I sprayed it all over my firewall and inner fenders. Didn't mess the paint up one bit. If you look at my build pics... that is the original paint on that firewall.
It is quite possibly the best cleaner I've used on the planet... bar none. I've used Purple Power and Castrol Super Clean... they work... but not as easy as Marine Clean.
Gary
