Old 05-25-2013, 07:03 PM   #1
68c10airstream
68c10airstream's Avatar
SS blazer a/c comp mount bracket question
just received a new SS trailblazer a/c compressor for my 68 c10 with a 2001 5.3. The compressor mounting holes don't line up on the factory 2001 a/c mounting bracket. I'm assuming that i need the SS trailblazer mounting bracket from probably a 2005-2007? The new compressor is a factory sanden trsa12b. The suction and discharge ports sit parallel to the engine crankshaft and are indexed point up high as this was my choice so i didn't cut the frame out. If i have to get the trailblazer bracket, does it have mounting holes on the front flange for the belt tensioner? Any help with pics and info would be great. Thanks, Brian F.
68c10airstream is offline   Reply With Quote
Old 07-27-2015, 02:30 AM   #2
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
Re: SS blazer a/c comp mount bracket question
Sorry to bring an old thread back up, but I would like to know the solution.
While researching putting an LS2 out of a 2006 Trailblzer SS into my '72 Jimmy. I would like to retain the TRSA12B compressor.
Did you ever find a solution on a way to mount the TRSA12B compressor on you 5.3?
Thank you,
Bob
Sandemonium is offline   Reply With Quote
Old 07-28-2015, 05:25 AM   #3
Undone
I would like to know this too.
Undone is offline   Reply With Quote
Old 09-29-2016, 03:11 PM   #4
Hart_Rod
Hart_Rod's Avatar
+2 and pictures please!
Hart_Rod is offline   Reply With Quote
Old 01-24-2017, 04:00 AM   #5
crakarjax
crakarjax's Avatar
I imagine that the stock compressor bracket for the trailblazer compressor would work right?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-24-2017, 04:23 AM   #6
crakarjax
crakarjax's Avatar
Like this one https://goo.gl/CWYSEK
Ah, and the lower portion bolts to the oil pan so a dropdown bracket has to be fabbed: http://67-72chevytrucks.com/vboard/s...8&postcount=36
Old 05-04-2017, 07:30 PM   #7
crakarjax
crakarjax's Avatar
[IMG][/IMG] I modified the bracket. The lower left hand side and center bolt were added by me. I will be using the lowest open bolt holes for through bolts and nuts on the back side instead of the lower bolts originally threading into the side of the trailblazer oil pan. i just installed 98-02 camaro/firebird oil pan and didn't want to weld onto the side of the pan so i modified the bracket instead
This looks even better
