06-25-2003, 08:45 PM | #1 |
Power windows Quit Help !
I went to put the windows up and the stoped working. It's a 87 Burb. Also the back window does not work either.
Any help would be great.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
06-25-2003, 09:05 PM | #2 |
STILL PLAYS WITH TRUX
Mario,
Go to the fuse block and you should see two small aluminum boxe's one is for your window's and the other is your pwr. lock's if you have them Now swap them and see if the lock's quit working and the window's start working if so then replace the bad aluminum box. The aluminum box is not a fuse even tho it's rated @ 30A. It's a self reseting breaker that opens when it overheats due to too much current draw and then it reset's when it cool's off. If you replace it with a new one and you still have a problem then you have either a bad motor or faulty wireing causing the breaker to open. Then you will have to start unhooking each door motor 1 at a time untill you find the bad one. But they go bad. Last edited by 87 STEPPER; 06-25-2003 at 09:16 PM. |
06-26-2003, 02:05 AM | #3 |
You might also check the power door lock/window relay, but that's what 87 Stepper might be describing.
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
06-26-2003, 05:12 AM | #4 |
LED King
A duh question but sometimes it works - have you tried looking at the power window fuse?
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
06-26-2003, 04:51 PM | #5 |
Thanks.
07-02-2003, 12:55 PM | #6 |
The power feed plugs into the fuse box in the accessory terminals at the top. My wife some how managed to kick the fuse box and knocked it out one time on our blazer.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
