05-26-2013, 01:34 AM | #1 |
Bump stops
So what do you guys with bump stops? upper and lower ones, stock arms.
any pics?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
05-26-2013, 09:08 AM | #2 |
67-72 parts collector,…
Re: Bump stops
Keep the upper.
Remove the lower.
05-26-2013, 09:14 AM | #3 |
Re: Bump stops
Should i just remove the actual bumpstop or should i also cut that whole raised part out of the control arm that the bumpstop mounts to?
05-26-2013, 09:20 AM | #4 | |
Re: Bump stops
I remove the part that holds the lower bumpstop,... but leave a little to use as a steering stop for the spindle.
05-26-2013, 09:57 AM | #5 |
Re: Bump stops
Ohhhhh alright guess i'll just see what I have to do as I go. Thanks for the info man, i'd +rep you if this forum used it.
05-26-2013, 02:52 PM | #6 |
Kill Bill...et
Re: Bump stops
Agreed. I cut everything flush except about a one inch "L" off the steering stop. I'm running 15" rims so I had to trim the lip off my A arm too. Left the top A arm stock.
