Old 05-26-2013, 09:13 AM   #1
bubs72gmc
72 gmc k15 4x4...HELP lost brakes
Hello all,
I was driving home from Virginia beach last weekend and lost all brakes, had to pump them to get stopped, wife did not like that ride home at all!
I do have power brakes with brand new pads on the front and decent drums on the rear.
My dad and I bleed all the brakes and still nothing. If I pump the brakes a few times then I get some brakes, but I'm lost now.
Anyone have any suggestion as to where to look next, how to check the master cylinder and/or the brake booster?
bubs72gmc is offline   Reply With Quote
Old 05-26-2013, 09:58 AM   #2
Wrenchbender Ret
Re: 72 gmc k15 4x4...HELP lost brakes
It is most likely the master cyl. I would pull the rear drums first & make sure something hasn't come loose like a wheel cyl. rod not in the brake shoe. If the rear brakes are OK & adjusted up replace the master cyl. Remans are not expensive. Bench bleed it before you put it on. Pull the vacuum check valve out of the booster & make sure there is no brake fluid in it.
Wrenchbender Ret is offline   Reply With Quote
Old 05-26-2013, 11:26 AM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
most likely the master cyl if none of the wheels are wet
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-26-2013, 11:47 AM   #4
ole dollor
ole dollor's Avatar
i agree with everyone else, you have a bad master cly.
ole dollor is offline   Reply With Quote
Old 05-26-2013, 02:23 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Is it a stock engine? Or do you have a snotty cam in it with a lot of overlap?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-26-2013, 10:55 PM   #6
bubs72gmc
Thanks for all the replies,
I took the check valve out to check the vacuum (was good) then I did have a little bit of brake fluid come out of the hole on the booster. Wiped it off and it never showed again.
I have a basic 350 with bolt ons no internals. So no cam issues.
I will try the master cylinder, as nothing is wet.
I will post my results later this week, thanks guys!
