Old 05-26-2013, 09:52 AM   #1
smoked68
smoked68's Avatar
what 5 speed will work?
Hi, Im sure this has been asked a thousand times but here we go anyway. What 5 speed can I get to put in my 68 c-10 swb. Can I use the same clutch bellhousing? Basically, which yr trans and what else do I need. Need to do this soon. thanks, mike
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 05-26-2013, 09:54 AM   #2
smoked68
smoked68's Avatar
Re: what 5 speed will work?
Its a small block, 350
Old 05-26-2013, 10:20 AM   #3
FL71C10
Read this thread. It's pretty helpful
http://67-72chevytrucks.com/vboard/s...d.php?t=407083
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 05-26-2013, 10:22 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
This is in the Engine and drivetrain FAQ section...
http://67-72chevytrucks.com/vboard/s...d.php?t=313954
LockDoc
Leon
Old 05-26-2013, 10:45 AM   #5
geezer#99
geezer#99's Avatar
I see mention of a weiand supercharger in your sig. If you're keeping that then a wimpy T5 won't live long. You'll need to step up a bunch to a TKO 5 speed. Here's a link.
http://www.classicchevy5speed.com/tko-details.aspx
