Old 05-26-2013, 01:28 PM   #1
dave5287
Question e brake cables
help i am looking for brake cables for my 1964 chevy k 20 4x4 long bed 127 inches truck hi have tried several places they have for two wheel drive only can anyone help only cable i have is front cable someone cut off rear cables dave
dave5287 is offline   Reply With Quote
Old 05-26-2013, 02:31 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: e brake cables
GM part #3824114 says 63-66 K20 with clamp, second series: but does not give overall length. Second series I believe refers to 63, production year had two series. I had new one's copied from my K10's old one's but you don't have old one's. Still the interior of the brake drum dimensions & components would be the same as a two wheel drive. You'd need the length of cable casing from the backing plate to the frame cross member where the parking brake casing horseshoe clips to the frame crossmember and the length of the remaining cable and threaded rod.
Inline has them listed: http://inlinetube.com/Brake%20Cables...s/bcables7.htm
Link to previous thread: http://67-72chevytrucks.com/vboard/s...d.php?t=391465
http://inlinetube.com/Brake%20Cables...ngs/cables.htm
clip
http://www.gmpartswiki.com/getbigpage?pageid=22355
Old 05-26-2013, 04:11 PM   #3
j.kirn
Re: e brake cables
inline tube has them
j.kirn is offline   Reply With Quote
Old 05-26-2013, 06:34 PM   #4
dave5287
Re: e brake cables
thanks i will give it a try dave
Old 05-26-2013, 09:06 PM   #5
maxwoof
Re: e brake cables
I actually called Inline tube on Friday looking for cables for my 62 k-20. They told me the dimensions for their 63 cables. They said the rear outer cables were 29 inches long. I think this is too short. I have an old Lisle replacement cable and it is about 40 inches. I am going to measure underneath the truck and see what would work. The 62 may be different from the 63.
They were very helpful on the phone. They can make one from a sample, or if you provide the dimensions
maxwoof is offline   Reply With Quote
Old 05-26-2013, 09:55 PM   #6
dave5287
Question Re: e brake cables
thanks i will try them my caseing was 35 inches cable was55 inches total
