Old 05-26-2013, 05:19 PM   #1
ReeseBobby
ReeseBobby's Avatar
Which conversion U-Joint for 10 to 14 conversion?
Gathering parts for my axle swap. Can someone advise what U-Joint I'm going to need for my 1970 3/4 ton that currently has a 10 bolt? Going to 14 bolt. I'm thinking 1310-1350 conversion but I'd love advise from someone who has done it on the same truck. I've read a ton of different opinions but I'm looking for info from someone who knows for sure. Thanks!
ReeseBobby is offline   Reply With Quote
Old 05-27-2013, 02:20 PM   #2
OldCreek
OldCreek's Avatar
Re: Which conversion U-Joint for 10 to 14 conversion?
A Dana 60 10 bolt? An Eaton/Corp 10 bolt? or a 1/2 ton 10 bolt converted into your 3/4ton?
More than likely you will only need a 1350/1350 u-joint. I suppose the one you have in there may work. However, your drive line length may be more the issue....
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 05-27-2013, 03:26 PM   #3
ReeseBobby
ReeseBobby's Avatar
The original corporate 10 bolt.
Old 05-28-2013, 04:58 PM   #4
Undone
Spicer 5-460X
Undone is offline   Reply With Quote
Old 05-30-2013, 03:59 PM   #5
snj8198
snj8198's Avatar
The FF14bolt pinion is about 3" longer than the Cop 10bolt. you will probably have to have the drive shaft shortened. If so, you might as well have the upgraded 1350 yoke installed at that time.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 06-02-2013, 11:02 PM   #6
ReeseBobby
ReeseBobby's Avatar
Got her done today. U-Joint stayed the same. The yoke was about 1.5" longer, but it sat in there just fine. Needed straps instead of the U-bolts. Those were a bear to find. Ended up getting some out of someone's drawer after two trips to NAPA. Long day, but she's in.
