Old 05-26-2013, 08:30 PM   #1
Tillik
Tillik's Avatar
1967 Gas Pedal Options
I would like to covert my pedal to a hanger. I've searched a few areas and haven't found anything shocking. I found a Lokar BaG-6164 or the Midnight Version(not sure of the part number). Anyone have some quick suggestions? If I'm going to spend $155 bucks for a gas pedal without the cable, I want some options. This is a daily driver and by no means intended as a show truck. Ill continue to surf.
The short story is, I will be doing some floor pan work later this summer and the floor is Flintstoned where the stock pedal mounts. If I can convert it to a hanger, then that will get me by for a while until i prep the floor work.
Thanks in advance.
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
Old 05-26-2013, 08:44 PM   #2
71swb4x4
71swb4x4's Avatar
Re: 1967 Gas Pedal Options
You mean a gas pedal without the rod right? The Lokar that you mention does use a cable. Why not go with a 71/72 pedal? It will be pretty cheap, and look stock.
http://67-72chevytrucks.com/vboard/s...d.php?t=170383
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-26-2013, 09:07 PM   #3
Tillik
Tillik's Avatar
From what I read the firewall mount is different for a 1971-1972 pedal. If you look at Lokar they carry two different pedal mounts. One is for a 1967-1970 and a 1971-1972. I have a 1971 Chevy truck I could rob a pedal assy from, however, am not sure it would bolt up. That is why I was looking around for options.
James B.
Old 05-26-2013, 09:12 PM   #4
71swb4x4
71swb4x4's Avatar
Right, that is why I posted the link to the thread that shows how you mount the cable style 71/72 pedal to the firewall of a 67/70. Check that thread out.
