Shift lever 3 on tree column
Gents. I'm rebuilding a 3 on the tree steering column I picked up from a member here. It did not come with a shift lever. Are the levers from an auto shift column the same?
Posted via Mobile Device |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Shift lever 3 on tree column
I'm not sure but figured I'd give you a bump till someone responds that knows
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Gonna bump this up. Reason I ask is I put the one from an auto column on it and I couldnt get it to shift. The pin you drive in to keep it in place is tight. Also the 3 speed column was dirty inside hence why Im rebuilding it.
Any Help? thanks. |
I have an extra one somewhere, I pulled from my panel when it was converted to floor shifter. I'll see if I can find it.
